Old 12-14-2017, 02:20 PM   #1
TakmaN
FIA World Rally Car Newbie
TakmaN's Avatar
Drives: 2011 CW GTI 6MT
Car is gasping at idle, no codes being thrown?
I started my car yesterday and noticed that at idle, it's acting really strange. I can hear the exhaust going ERRRRRerrrrrERRRRRerrrrr (basically getting loud then quiet in a rhythmic pattern). My RPMs look normal but my boost gauge is bouncing up and down in tune with the weird exhaust sound pattern. I also hear a weird wheezing noise from the engine bay. Nothing looks out of place and I don't see anything leaking when I checked below my car.
I started it again this morning and my car sounds like its about to choke/shut off and then it bounces to life for a second then it sounds like its going to choke again. I recorded a video yesterday and posted it below. If you raise the volume you can hear my strange exhaust sound pattern and at the end it shows the boost gauge bouncing.
Anyone have any ideas what's going on? I drove it down the street after noticing it yesterday and it drives fine. But I'm worried as it seems like it's much worse today.
2011 Candy White GTI 6MT
Mod List: Unitronic Stage 1 | Neuspeed P-Flo | VMR 810 | ST Coilovers | Magnaflow Catback | Dieselgeek Sigma 6 | OEM LED Tail Lights w/ LED Reverse | Newsouth Boost Gauge | Boomba Shift Knob | Euro Switch | Euro Cup Holders | OEM Front Lip | Blind Spot Mirror | Soundaktor Delete | VAG-COM Coding
Wish List: Unibrace UB | FFE Shift Bracket Bushings
TakmaN is offline   Reply With Quote
Old 12-14-2017, 02:32 PM   #2
TheCor
Drives: 2013 GTI Wolfsburg Edition
Bad PCV? Supposedly a whistling sound coming from under the hood is often the result of a bad PCV valve, which is very easy to replace. Not sure why your car would be surging like that though. How does it drive otherwise? It is normal under load?
_______
HR 24mm Rear Sway | aFe Pro Dry S Drop-In Filter | Do R8 Coilpacks count?
TheCor is offline   Reply With Quote
Old 12-14-2017, 02:52 PM   #3
TakmaN
TakmaN's Avatar
I didn't want to drive it today since it sounds/feels worse. The car would shudder like it's about to stall then pops to life and repeat. It drove fine yesterday and I did a quick pull and the boost levels were like usual. It does feel normal under load.
I replaced the PCV valve with an updated one myself maybe less than a year ago. The surging part is weird and worrying me.
Old 12-14-2017, 03:03 PM   #4
Boscogn
FIA GT Champion
Boscogn's Avatar
Drives: CSG 2013 GTI DSG 4DR
Have you gotten the car to temperature and does it go away?
Edit: also building boost at idle is odd have you done any work to anything recently? My thoughts are possibly a vaccum leak?
Wish List: Golf R InterCooler | Unitronic or IE CAI | P3 Air Vent Boost Gauge | 034 Motorsports RSB
NOTE: Please PM me if you are selling anything in my wishlist! Also check out my Build Thread!
Boscogn is offline   Reply With Quote
Old 12-14-2017, 03:07 PM   #5
TakmaN
TakmaN's Avatar
I got it at least close to temperature yesterday and no change. If anything it got worse the longer I drove it so I only took it for maybe 4 miles.
I just looked it up and it seems like I might have a vacuum leak? But I would think a check engine light would pop on for that. I had my turbo replaced a handful of months ago and it drove like a top after. I also had my timing chain tensioner replaced a few months after and no issues after until right now.
Old 12-14-2017, 03:38 PM   #6
notovicrious
notovicrious's Avatar
Drives: 2011 GTi 2.0T
http://www.golfmk6.com/forums/showthread.php?t=84452
Old 12-14-2017, 04:16 PM   #7
TakmaN
TakmaN's Avatar
Thanks for that. I'll go check for any intake leaks and what not. The weird thing is my RPMs aren't bouncing or moving, just my boost levels.
I just remembered that I attempted to shift the front sub-frame a few weeks ago to get my camber lined up on the front wheels. I wonder if I screwed something up in that process. Unfortunately, my lift and car tools are stored at my parents house which is a 2 hour drive away. I don't really feel confident in driving that far with my car's situation right now. I might try to see if I can make it to a shop.
Old 12-14-2017, 04:24 PM   #8
TakmaN
TakmaN's Avatar
I just went out again and started my car, the check engine light now came on and I used my code reader to pull the following:
1) Air Intake Leak
2) Engine Cylinder 4 misfire
The engine now sounds likes the cylinders are trying to punch their way out of the engine. I'm hoping its just a bad spark plug or coil pack. Come to think of it, I'm due for a spark plug change. Would it be safe to drive to a shop? I took another video below and you can hear the knocking noise in the background.
Old 12-14-2017, 05:23 PM   #9
jettaglis
FIA GT Champion
jettaglis's Avatar
Drives: '88 gli, '11 cc, '12 gti
Take the engine cover off, look at the arm coming off the intake manifold on the d/s side. Put your finger next to the intake manifold hole and its probably sucking air. If that is the case, it could still be covered under warranty extension for the intake manifold.
Uni stage 3....gt3076
Unitronic, Rotiform, and H&R at Vw of South Charlotte
Instagram: vsc_tuning
jettaglis is offline   Reply With Quote
Old 12-14-2017, 05:57 PM   #10
TakmaN
TakmaN's Avatar
Iím sitting in a tow truck headed to a shop now. Iíve had my intake manifold replaced twice under warranty but unfortunately Iím probably out of warranty now with over 130K miles on my car .
Old 12-14-2017, 10:43 PM   #11
BudgetPhoenix
Drives: 09 GLI
I had something similar to this, it ended up being the gasket on the PCV. If not related to PCV im guessing some other vacuum leak-
Old Yesterday, 03:11 AM   #12
Boscogn
FIA GT Champion
Boscogn's Avatar
Hoping it's nothing serious let us know what shop says.
