Old 04-03-2017, 05:34 AM   #1
IzanAzman48
Drives: 2012 Volkswagen Golf GTI
Annoying squeeling noise from the engine!
Hello, I'm new to the forum btw.
I have a 2012 Vw GTI DSG, a few months back (around January 2017) I changed the belt tensioner because it created a rattling sound from the engine. All was well until the noise appeared again, this time I replaced the belt, as the workshop where I bring it to recommended it to be changed. No more rattling sound since, but now I have this wierd belting sound. The squeeling sound usually occurs after a cold start and when accelerating at parking lot speeds. Brought it to the workshop, again! Now they say their not sure but possibly the bearing for the ac compressor or something. Anybody here have the same problem?
IzanAzman48 is offline   Reply With Quote
Old 04-03-2017, 05:50 AM   #2
Laimface
Laimface's Avatar
squealing sounds are common with failing PCV valves, which are on top right of the engine between the coil packs
Old 04-03-2017, 07:57 AM   #3
Roctre
Roctre's Avatar
Drives: 2011 CW GTI
If its the pcv you can check by pulling the dipstick out a little bit and if the sound goes away its pcv.
Old 04-03-2017, 10:29 AM   #4
IzanAzman48
Wait... How? You mean drive around without the dipstick? Sound only occurs when driving after a cold start, and after a while it goes away.
Old 04-03-2017, 10:41 AM   #5
Roctre
Roctre's Avatar
Drives: 2011 CW GTI
Just when its sitting still idling
Old 04-03-2017, 07:34 PM   #6
IzanAzman48
Tried it out but didnt do anything. Something to do with the AC is presume since it disappears when I turn off the AC
Old 04-04-2017, 07:43 PM   #7
IzanAzman48
Also, squeeling doesn't happen when the car is stationery
Old 10-05-2017, 12:56 AM   #8
Slavin
Drives: 2012 MK6 GTI
how did you get the tensioner out? i have the tension off and i found something to fit in the hole to hold it in place, but i cant seem to get it out.
Slavin is offline   Reply With Quote
aircond, annoying, belting, noise, squeeling
