Old 04-10-2017, 02:42 PM   #1
FlowMK6
FlowMK6's Avatar
Drives: Golf 2.5 5spd
What do you think of this pulley ?
As the title say, what do you think of this pulley:
https://www.ecstuning.com/b-ecs-part...y/1-07k-008kt/
Would it worth to put this on a manual car ? Does anyone have this ?
I'm about to change the belt, so I might change the pulley at the same time + the tensionner.
Old 04-10-2017, 03:03 PM   #2
bart2278
bart2278's Avatar
http://www.uspmotorsports.com/Engine...er-2.0TSI.html
Old 04-10-2017, 03:06 PM   #3
jay745
jay745's Avatar
Originally Posted by bart2278 View Post
OP has a 2.5 golf, that won't fit.
Unfortunately they don't make a fluidampr for the 2.5. Honestly those lightweight pulleys do more harm than good. If they ever come out with a fluidampr for your car get that, but if not then just use your oem pulley.
Old 04-10-2017, 03:08 PM   #4
mikeleemk6
mikeleemk6's Avatar
Drives: Shadow Blue GTI MK6
The link he posted from ecs says its for a 2.5?
Old 04-10-2017, 03:10 PM   #5
jay745
jay745's Avatar
I was talking about the link Bart posted, was a fluidampr for a gti
Old 04-10-2017, 03:14 PM   #6
bart2278
bart2278's Avatar
oh ya my bad. Listen to Jay
Old 04-10-2017, 03:22 PM   #7
mikeleemk6
mikeleemk6's Avatar
True that. They arent the same thing posted in op and the fluid damper?
Old 04-10-2017, 03:23 PM   #8
jay745
jay745's Avatar
No they are definitely not the same.
Old 04-10-2017, 03:27 PM   #9
pcfoo
Drives: 2013 Golf GTI
I would consider a lighter pulley but not an under-driving one.
2013 GTI DSG 4dr @ Candy White, 18" Lagunas
Mods: Stratified Flash Tune || P-Flo/AEM || R8 Coils || Rest-Still-Bone-Stock
Wish List: Install Eibach 23mm Rear Sway Bar || PSS || Stoptech Slotted Rotors & Street pads || Lighter Wheels
pcfoo is offline   Reply With Quote
Old 04-10-2017, 03:34 PM   #10
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
The fluidampr is actually heavier than an OEM pulley and filled with silicone. It's purpose is to balance out the harmonics of the engine, makes things feel smoother and you free up some extra power because of it. It's also the same diameter as the OEM pulley.
An underdrive pulley is a smaller lightweight pulley. You have less rotational mass and its a lighter weight. I think different motors respond to these types of pulleys differently, but if I remember right they can actually mess up the motors harmonic balance and add extra wear to the car.
A fluidampr absorbs unwanted vibrations, but an underdrive pulley will likely do the opposite.
