Old 04-21-2017, 02:24 PM   #1
steve9842015
Drives: 2011 4 dr GTI /DSG
K04, California, and Smog
Hey all,
Haven't been on here in forever, but it's the first time I need to smog the car and I'm having quite a bit of issues.
K04, I have the non test-pile and a 42dd spacer on the last oxygen sensor (place doesn't do visual). I'm having a problem getting all monitors to clear readiness, specifically the cat itself. I keep throwing a P0420 no matter what I do with the spacer it seems. I've extended it out as far as I believe it can go, I've oriented the spacer towards the front and rear of the car, etc, but within 10 minutes of driving on stock file it'll pop a soft code and eventually the MIL. Any other suggestions?
I've been trying to get everything cleared with VCDS and I can get all monitors to show passed except for the cat, once again. Using basic settings on group 046 (cat bank efficiency), I can run the test and it'll eventually show CatB1 Not Okay.
My question is, does anyone know the parameters for the cat efficiency to pass readiness tests? During the test the conversion number will sit around 0.03-0.06, then after a minute or so it'll show Not Okay.
Any help would be greatly appreciated.
For other K04s in California, what has worked for you?
2011 United Grey 4dr GTI | APR k04 v3.1 | GodSpeed v2 IC | IE Intake | Billy Boat TBE | ST X Coils | Depot Golf R LED Tails | GFB DV+ | AWE S3 TOP + Neuspeed TPB | Neuspeed RSE12's + PSS | NSP Boost Gauge | 034 Street Density
steve9842015 is offline   Reply With Quote
Old 04-21-2017, 05:52 PM   #2
nafljhy
Drives: 2011 UG GTI
you could try using a mini cat o2 extender and the spacer or just the mini cat o2 extende.
https://www.amazon.com/Minicat-Senso.../dp/B00CBKEC06
something like that.
Old 04-22-2017, 12:10 PM   #3
Geryon86
Geryon86's Avatar
Drives: MK7 R
I temporarily swapped in a modified stock DP.
16' LB R | DSG | APR Stage II HT |
11' SB GTI
|DSG|APR v3.1|CTS K04|
Geryon86 is offline   Reply With Quote
Old 04-22-2017, 12:16 PM   #4
GIACUser
GIACUser's Avatar
Drives: 2008 MKV EFR7163
I use stock downpipe, not much work and a sure thing.
| 2008 GTI under construction as of July 2017 | EFR7163 | LSD | DriverMotorsport tune | UNI custom DSG tune | Aquamist W/M | Brembo brakes f/r |
| YCW Coilovers | fifteen52 fender flares | 18x9.5 RPF1 w265/35 Michelin SportCup2 | Recaro Speedseats |
Old 04-22-2017, 12:54 PM   #5
steve9842015
Is there enough space to add a bung on a cfba downpipe? Always heard people needing to use a ccta
Old 04-22-2017, 03:38 PM   #6
NUISANCE
Drives: 2012 VW CC Rline
Just swing down south and borrow my modded CCTA downpipe, I'm an hour south of San Jose. You can use it to pass, I used it to pass the state ref inspection, but I will need a deposit to make sure I get it back. I won't charge you for the use and I will give you back 100% of your deposit. Let me know.
NUISANCE is offline   Reply With Quote
Old 04-22-2017, 03:40 PM   #7
NUISANCE
No there isn't enough space and you can't just swap in a CCTA downpipe because you have to modify the mounting flange and weld in a bung under the car. I already did all that work for you though
Old 04-22-2017, 11:22 PM   #8
Mk6_vic
Drives: Mk6 GTI 2011. 2-Door. Candy White
when I go k04 ill take part in that transaction please ^ lol
Mk6_vic is offline   Reply With Quote
Old 04-24-2017, 05:18 PM   #9
steve9842015
Thanks for the offer! I ended up getting it to pass smog today, I really didn't want to have to deal with swapping downpipes if I could avoid it.
I ended up putting a spark plug non fouler in the pre-cat sensor and the 42dd+non fouler in the post-cat sensor and it cleared readiness immediately! Smog place was a simple obdii plugin and they didn't do a visual so it only took a few minutes. Took the spacers off immediately after and finally got this thing registered.
Thank goodness. Putting these away until next time.
Old 04-24-2017, 06:49 PM   #10
BudgetPhoenix
Drives: 09 GLI
I want to know where this place is
Old 04-26-2017, 10:44 AM   #11
damagi123
damagi123's Avatar
Drives: 2012 GTI DSG
so where do you have the sensor thats supposed to be on the turbo?
Old 04-26-2017, 10:48 AM   #12
ebuuz
ebuuz's Avatar
Drives: Mk6 GTI
Let me get this straight.
If you can run the k04/f23t on stock mode without throwing a CEL (via spacers/spark plug non-foulers), then you will pass OBDII inspection. Correct? This is assuming the shop overlooks visuals.
2012 CW 6 speed. F23T on APR k04 v3.1, APR Carbonio, CTS turboback, Clutchnet 6 puck disc, 034 Street Density motor and transmission mounts, Hawk HPS 5.0, Motul RBF600, Newsouth boost gauge, DieselGeek SS
Dyno vid of my car
ebuuz is offline   Reply With Quote
Old 04-26-2017, 11:27 AM   #13
steve9842015
Yep, as long as you have a non test-pipe file for stock mode.
That sensor is at the very top of the flange on the down-pipe (billy boat tbe).
Old 04-26-2017, 11:58 AM   #14
damagi123
damagi123's Avatar
do you know if all aftermarket cbfa downpipes have a bung for the sensor from the turbo?
I have an ultimate racing CBFA and the lower part I can see my 2 sensors but i cant get far enough under right now to see if theres a bung near the flange if I wanted to go K04
