Old 04-25-2017, 11:52 AM   #1
darkGTI
Drives: VW GTI MK6
Wheels choice weight vs width
So right now I'm running Enkei Fujin 17x7.5 and they work well, but I was looking for some more width and also they don't clear NSQBBK, so I found these:
-Team Dynamics Pro Race 1.2 17x9
So my enkei's weight around 17lbs per wheel, and team dynamics will weight around 20lbs per wheel. So I was wondering if 3 lbs per side is a good sacrifice for more tire thread? Considering I spin tires on the 1-2 gear running RE71R's.
I'm worried for team dynamics wheels to clear NSQBBK and also not hitting anything inside the wheel arc. So I was thinking 45mm? or should I go 40mm?
I'm sitting pretty high, so I'm not worried the tires rubbing.
APR Stage 2|Unitronic Custom Intake|R8 Redtops|HPA SS|SPULEN Coilovers|SPM 3'' CBE|AWE Downpipe |034Motosports CatchCan|Unibrace XB|Unibrace UB|GFB DV+|Neuspeed TOP|BSH TBP|Godspeed IC|HSTuning RSR clutch|Wavetrac LSD |Fluidampr Crank Pulley|Polar FIS|PTP Turbo Blanket|H&R Sway Bar 26mm front sway bar|034Motosports 25.4mm rear sway bar|TyrolSport Front and Rear Deadset|NSQBBK|SuperPro
darkGTI is offline   Reply With Quote
Old 09-03-2017, 08:20 PM   #2
George11
Drives: VW GTI 2011
Necro time, Did you finally get a different set of wheels? I am unsure of anything 9 inches wide, I currently run RSE05 17x7.5 17lb wheels no hub ring or spacer.
My Build Thread ⧸ APR Stage 2 ⧸ RSR Clutch ⧸ Wavetrac LSD⧸ 42 Draft Design downpipe ⧸ Koni Coilovers
George11 is offline   Reply With Quote
