Old 12-26-2015, 06:13 AM   #1
Pacs
Drives: Golf 6 R
Pacs Golf 6 R build Stage unknown (some pic added )
Hi
All new here
Ride is a 2010 Golf 6 R stage ???
When i got this car it was semi modded allready so iam not sure what parts are fitted
Prewus owner have add
BCS turboback
THS intercooler.
Auto Tech high pressure fuel pump
ko4 Hybrid Turbo with larger turbine / lightweight wheels .
Heat coated surfaces. Ported manifold about 4%. Reinforced bearings,
which makes it suited for 10-15 % more pressure
It was supose to do 380-390hp but it had some air intake
problems and some injector problems as well so outcome was 340 HP
i meet up with a local tuner and we added some stuff :-D
Revo air intake
Rs4 injectors
R8 ignition coil
new sparkplugs
new oil
oooh and we changde the turbo to a TTE420
Car is now pushes 460HP and 597nm
We also did do another set up at 457 HP and 611nm
Custum DGS file too
We did test on normal road with streettyres and racelog
0-100 km/h 3,4 sec
80-150 km/h 4,8 sec
Atm we are working on WMI and hope it can provide approximately 60 hp
And we add a boost controller as well
Iam thinking on mabye getting a HPA intake manifold
but iam not sure what we can do with that
I saw that on APR stage 3 they add 35-50hp so i am not sure if we do that
and hope for 550 HP ?
We may have max out the TTE420 around the 500 HP mark
More info to come when we done with the WMI :-)
I upload some pics and if possible, a video of the dyno test
Pacs is offline   Reply With Quote
Old 12-26-2015, 06:15 AM   #2
Pacs
Drives: Golf 6 R
Iam going for the sleeper look if you can say that with the R
Removing all bagdes on the car and if possible the ones on the breaks as well
The engine need too be as OEM as possible and i will change cooler and washer caps to blacks
I hope we can change the Revo intake with a R36 and ad a TTRS engine cover
I really want to get the WMI tank replaced and the water/meth stored in a washer tank on the other side of the bumper
We are not sure if that is possible but I think we give it a go
Revo Air Intake
Car on dyno
Old injectors
RS4 mounted
Carbon all over but it got cleaned
New TTE420
Car back on dyno all linked up
Outcome of some hard work
Old 12-26-2015, 09:38 AM   #3
Formula 2 Driver
zrickety's Avatar
Sounds good, where are the pics?
Old 12-26-2015, 10:54 AM   #4
Pacs
Drives: Golf 6 R
On the way just trying to find out how
Old 12-27-2015, 12:30 PM   #5
Pacs
Drives: Golf 6 R
some more pic form the build
File Type: jpg 12395480_1124662790885870_786007283_n.jpg (133.3 KB, 912 views)
File Type: jpg 12395073_1124663827552433_93941610_n.jpg (136.5 KB, 1983 views)
File Type: jpg 1957383_1124679784217504_997296951_n.jpg (58.4 KB, 1925 views)
File Type: jpg 702736_1124670614218421_637491847_n.jpg (61.0 KB, 1954 views)
File Type: jpg 12404460_1125641904121292_1338550954_n.jpg (145.7 KB, 1412 views)
Old 01-05-2016, 05:41 PM   #6
hooligan74
FIA World Rally Car Newbie
Drives: '13 Golf R 4dr/CSG/6mt
Nice results!
hooligan74 is offline   Reply With Quote
Old 01-11-2016, 07:34 PM   #7
Pacs
Drives: Golf 6 R
Tnx
More pictures on the way but sadly the engine broke a valve
Old 01-11-2016, 09:16 PM   #8
kern417
Formula 2 Driver
Drives: '09 Jetta
how
do a burnout.
kern417 is offline   Reply With Quote
Old 01-13-2016, 07:11 PM   #9
Pacs
Drives: Golf 6 R
Originally Posted by kern417 View Post
how
Valve spring broke then the valve got a slap from the piston
Old 01-14-2016, 08:52 AM   #10
kern417
Formula 2 Driver
Drives: '09 Jetta
ouch. any ideas what cause the valve spring to break
do a burnout.
Old 07-07-2016, 04:56 PM   #11
Pacs
Drives: Golf 6 R
Week spring I guess ?
Well we are back on track
Car is running now at 475 HP and 601 NM I think
We did this
1 New piston old model ( we found one in Germany )
All new valves
All new valve springs
New timing belt and water pump
New Cam follower
Gearbox flushed and new oil
New RS4 injectors
WMI is mounded but not all maxed out
Sadly we forgot too get the top ported for a better flow
Well and we forgot to change the cam chain and tightener but that's fixed now
Breaks are also fixed and now it is time for a new DSG clutch and flywheel
I am looking for some upgrades and SSP clutch look fine but I don't know about flywheel
Any 1 got info on upgrade flywheels let me know
Old 02-22-2017, 08:08 PM   #12
Pacs
Drives: Golf 6 R
Just some race times
File Type: jpg 13614988_10210009875514197_3811130904077242396_n.jpg (77.9 KB, 1268 views)
Old 02-23-2017, 04:36 PM   #13
bebersol
Rally Car Champion
bebersol's Avatar
Originally Posted by Pacs View Post
Hi
All new here
BCS turboback
THS intercooler.
Revo air intake
Rs4 injectors
R8 ignition coil
new sparkplugs
new oil
Custum DGS file too
0-100 km/h 3,4 sec
80-150 km/h 4,8 sec
457 HP and 611nm NICE!
Bunch O'Stuff :-)
Old 02-23-2017, 04:41 PM   #14
bebersol
Rally Car Champion
bebersol's Avatar
is that a stock location for the battery?
Bunch O'Stuff :-)
