Old 04-30-2017, 11:56 PM   #1
ithrashmotors
ithrashmotors's Avatar
Drives: Mk6 gti
Oil around turbo
Noticed oil around the turbo and wonder if this is normal? I had the return line replaced by the dealer when they did my rear main seal less than 6k ago. I never have oil spots in my drive way and I just did 1000 miles on my fresh oil change and When I checked the dipstick I was right under the max line. Any ideas?
APR stage 1//Carbonio intake//R8 coilpacks//GFB DV+
ithrashmotors is offline   Reply With Quote
Old 05-01-2017, 11:21 AM   #2
corydd
corydd's Avatar
Drives: '10 CW GTI DSG Autobahn
How's your PCV valve?
'10 CW DSG GTI Build Thread & Flickr * APR Stg 1 * Depo Tails * Magnaflow CBE * OEM Lip * VW Motorsports Wheels * VWR Springs * Stoptech Pads * DeAutokey LED's * 24mm H&R RSB
corydd is offline   Reply With Quote
Old 05-01-2017, 11:24 AM   #3
ithrashmotors
Drives: Mk6 gti
As far as my scanner says everything is fine. Car runs fine I just always have this really small oil leak. Like I said tho it never hits my driveway and I'm not losing huge amounts of oil. I wonder if the dealer tightened my return line enough. Have to check after work today
Old 05-01-2017, 11:49 AM   #4
Laimface
Laimface's Avatar
I have oil all over my turbo haha. My DV wasn't tight and my turbo muffler flange is leaking slightly. I really need to get a turbo muffler delete but money is a thing.
Old 05-01-2017, 12:02 PM   #5
ithrashmotors
Drives: Mk6 gti
I have a gfb dv+ and it's on there right.
Old 05-01-2017, 02:22 PM   #6
Fastball
Drives: CSG 2011 GTI
...My DV wasn't tight...
What is DV? I have the same sort of oil residue around the rear passenger side of the engine on my 2011 with 56k on the odo.
Thanks
Fastball
Carbon steel gray metallic 2011 GTI 4-door w/ sunroof. 6 speed DSG A/T - ECS Turbo Outlet w/ Muffler Delete - VMR V701's Hyper Silver - Floor mat kit - Clear side markers - LED lighting - Under seat stowage bin - unSoundaktored - DEI Soft Chirp Horn - deAutoKey LED turn signals.
Fastball is offline   Reply With Quote
Old 05-01-2017, 07:57 PM   #7
FocalPoint
FocalPoint's Avatar
Drives: MKV GTI/MKVI GTI
Diverter valve.
Old 05-01-2017, 09:48 PM   #8
FriggenT
Oem turbo? My pcv needed to newest revision and then it stopped.
Old 05-01-2017, 11:51 PM   #9
ithrashmotors
Drives: Mk6 gti
Did a good inspection tonight after work and I think I can safely say the top m8 triple square on the return line that runs to the turbo is leaking. The ones on the block are bone dry and just the top m8 is wet with oil.
My m8 triple square socket I have can't clear the line in front of it so I'll get the proper tool thru Amazon. Happy to say my intercooler hoses are still not leaking since putting in new o rings but I've found yet another suspicious oil seepage. This one is coming from the transmission where it meets the plastic cover.
I checked the dsg filter and it's bone dry up there. This has me concerned as I don't want to drive with low dsg fluid. It's not seeping to the point where it hits the drive way but it is hitting the belly pan and the bottom of the trans is wet. Any of you guys have this or experienced this. I have 1k left on power train so Im more than likely gonna head to the dealer this week. Any input is appreciated.
Old 05-02-2017, 12:27 AM   #10
ithrashmotors
Drives: Mk6 gti
Bottom of trans with very light coat of oil on it that's seeping out of the plastic cover
Old 05-02-2017, 01:28 PM   #11
ithrashmotors
Drives: Mk6 gti
So I looked at my receipt from my rear main seal repair and it's says they replaced the mechatronic cover and turbo return line gasket, sadly both are still leaking. Car is scheduled to go into dealer today. Hopefully they can get it right this time.
Old 05-02-2017, 01:34 PM   #12
uglybastard
uglybastard's Avatar
good luck
..246.............. Insta
Old 05-03-2017, 01:30 AM   #13
Brawn80
Brawn80's Avatar
Drives: Golf GTI MK6
Where did you find a separate part number for the o-ring? It looks like I might need some too. Along with that I need a replacement o-ring for the lower hose coupling that leads to the radiator. VWs parts catalogue just gives me the full replacement hose. This spring I've been replacing shit all over chasing leaks. I was/am leaking oil, water, and air. Today I replaced a seemingly healthy Rev D DV (I was hoping for that to fix my lack of boost, and well it didn't). When I replaced this, I did notice some oil on one or two bolts on the turbo but they were seemingly not near anything that should be leaking and it was solely on the bolt. On a side note.. when I disconnected the DV connector, a decent amount of oil came dribbling out. It came from within the DV through the small gap the metal prongs come out of from the body of the DV. Already replaced oil pan. It seems like there's some oil seeping out from where the edges of the timing chain cover and the exhaust manifold meet the body of the engine. A lot of my problems seem to be circling back to a possible bad PCV? I'm just starting to get tired of throwing money at the car without knowing if it's a definite fix. Like my water pump and possibly the DV. Both of which still seem to work, it was just more a gasket or an o-ring that needed to be replaced. But each item replaced did get me one step closer to recovery. Plus now I have spare parts for the future. The weeks I've spent waiting for parts to arrive after each new issue I find is grueling. But I still have high hopes for going ko4 this summer.
APR Stage 2 CSG 2010 DSG GTI 2 Door,SPM street turboback,Hidden Hitch,Swagman G10 bike rack on hitch,OZ Leggera 18"+BFGoodrich gForce sport comp2,KW V1 coilovers,Hardwired+Blendmounted Escort Passport 8500 X50,35% tints all around,Airbag warning label delete,Depo Dark Cherry LED tails,ECS blue tinted blindspot mirrors,deautokey LED plate lights,Michelin X-Ice Xi3(winter), Modshack Intake,R8 Coil-packs,NGK Iridium plugs,Torque mount,Rev D DV,EBC slotted front disks with EBC redstuff pads.
Brawn80 is offline   Reply With Quote
Old 05-03-2017, 04:07 AM   #14
Laimface
Laimface's Avatar
3C0-145-117-F
https://shopdap.com/store/3c0-145-117-f.html
