Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - > Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 05-31-2017, 11:19 PM   #1
Drives: 13 GTI wolfsburg edition
Replacement Horn? Warranty?
i have 2013 GTI with 39K Mile and sec owner . and my horn does not work.
if i press no sound other than clicking.
will this cover by warranty if i have one?
2013 GTI MK6 Wolfsburg - Stratified Tune - Carbon Fiber Intake System with Rear Inlet Pipe - APR DOWNPIPE - APR INTERCOOLER - BORLA CATBACK EXHAUST - APR DSG Tune
JISUN_GTI is offline   Reply With Quote
Old 06-01-2017, 07:33 AM   #2
Blakcard's Avatar
Did u check fuses?
Old 06-01-2017, 09:22 AM   #3
damagi123's Avatar
Drives: 2012 GTI DSG
this has happened 2 different times on mine in 70k miles. its not likely its fuses, the dealer told me it was the clock spring
APR K04 V3.1, APR DSG tune, APR Intake, Uni intercooler, UR Catless Downpipe, CTS Chargepipe & TOP, W.A.L.K, APR 27mm Front and Rear Sways, ECS Dogbone insert, 034 Subframe Collars, Pedalbox throttle controller, 17" Fujins on Conti DW
Old 11-10-2017, 09:18 PM   #4
I've had multiple horns go out on my GTI. Its a quick job and it was covered under warranty for me. There is actually two horns but the one that goes bad is the one that honks when the button is pressed. I suggest everyone test their horns out periodically because that's a very small thing that can mean the difference between someone crashing into you or not.
Syze00 is offline   Reply With Quote
