Old 06-02-2017, 09:26 AM   #1
james9120
james9120's Avatar
Drives: 13 R
VWR springs ride like ass!
Never expected lowering springs to ride so harsh.. every bump even at low speeds sounds like I hit the struts limit on travel, feels horrible. Maybe the shop installed the wrong? Is that possible?
Sent from my SM-G955U using Tapatalk
james9120 is offline   Reply With Quote
Old 06-02-2017, 09:48 AM   #2
thedude4bides
thedude4bides's Avatar
Drives: '12 Golf R
Even when mine were breaking in they still felt no harsher than stock. How many miles do you have? Are still on OEM struts? Did you replace end links?
Old 06-02-2017, 09:52 AM   #3
james9120
james9120's Avatar
Drives: 13 R
Didn't replace anything, 48K miles on the car and maybe 60 miles on the springs so far. When I hit a bump I get a thunk from the drivers side, might have to check it out after the weekend.
Old 06-02-2017, 09:54 AM   #4
joeyfrost
Drives: MK6 Golf R
Im on vwr spings and strut setup and its just too damn good. Make sure its been installed properly and it is possible for the rears not to be seated correctly as far as the fronts its pretty straight forward
Mk6 Golf R | APR Stage 2+
MKVI Golf R
APR II +
joeyfrost is offline   Reply With Quote
Old 06-02-2017, 09:55 AM   #5
Jaber
Modero
Jaber's Avatar
Check both ends of the endlink on that side.
Member Journal
Old 06-02-2017, 10:43 AM   #6
thedude4bides
Drives: '12 Golf R
Yeah dude... shoulda replaced end links, strut mounts and bearings. Sucks but your gonna have do that...
Edit: Start with end links because that's super easy and if it fixes you may get away with putting off the mounts and bearing
Old 06-02-2017, 10:45 AM   #7
Jaber
Modero
Jaber's Avatar
^ I would of for sure done strut mounts and bearings. Along with new hardware to replace the stretch bolts.
Member Journal
Old 06-02-2017, 11:21 AM   #8
TimS
Drives: '12 Golf R
The mounts and hardware are cheap, and you have to take it all apart anyway. There's no reason not to replace it all.
Old 06-03-2017, 11:26 AM   #9
james9120
james9120's Avatar
Drives: 13 R
Driver side strut is locked up, most likely my issues lol. But I will invest in a refresher kit as well. Thanks for all the help!
