Old 06-07-2017, 02:32 PM   #1
Vikingsloth
Vikingsloth's Avatar
Drives: 2011 golf 2.5
2.5l turbo build help thread
Came upon a turbo kit that I'm picking up Saturday. T3t4 turbo with blow off, manifold, oil lines, and hook ups. I need a downpipe or connection to my test pipe. Any suggestions? Can I just use a downpipe from a gti? Help!
my mk6 golf 2.5 💣 H&R sport cup kit, whiteline adjustable sway links, alzor 881 18x9.5 ET40 wearing 225/40r18 nankang ns20's. afe dry intake, usp testpipe, eurojet exhaust, vacuum pump delete, r8 coil packs, eonon GA6153F headunit, blue LED interior swap. soon to be: git flat bottom steering wheel, IE tubing swap, IE valve cover, intake manifold????, tune??
Vikingsloth is offline   Reply With Quote
Old 06-07-2017, 02:49 PM   #2
FlowMK6
FlowMK6's Avatar
Drives: Golf 2.5 5spd
How does the exhaust manifold looks ? And what turbo kit are you looking at ?
Old 06-07-2017, 02:55 PM   #3
Vikingsloth
Sorry for shitty pic quality
Old 06-07-2017, 03:33 PM   #4
MLue1
IDK it looks low quality to me, it's in the same league as this cheapo turbo Kit for the 2.5 Jetta that always pops up.
http://www.hansautoparts.com/25TurboKitDescription.aspx
With the so called blow off valve (Black part connected to the Manifold) even clear the hood once the manifold is mounted? In our cars, clearance is a big packaging problem, so make sure you are OK before you buy or be stuck with it.
Old 06-07-2017, 03:41 PM   #5
Vikingsloth
It should clear. If not I can set up a diverter and that should take less space.
Old 06-07-2017, 09:13 PM   #6
FlowMK6
FlowMK6's Avatar
The exhaust manifold looks cheap and a bit small, are you sure it's for a 5 cylinders ? Is there an other pipe ? I think the actual pipe is just a pipe for atmospheric dump and it looks like a external wastegaste. There is probably an another pipe which goes from the turbo exhaust housing to the downpipe, you will probably need some custom pipe work.
Old 06-08-2017, 12:06 AM   #7
Vikingsloth
I'll take more pics this Saturday
Old 06-08-2017, 09:13 AM   #8
davserbic
davserbic's Avatar
Drives: Golf MKVI
Oooh, I've seen this guy selling this kit for a bit — was always curious but never took a chance on it. VERY curious to see what you find.
Golf 2.5L Build Thread | Airlift Slam Series + V2 Management | APR Carbonio | Mercedes Alphards | Golf R Conversion |
FOLLOW ME ON IG: @DAVSERBIC
davserbic is offline   Reply With Quote
Old 06-08-2017, 03:42 PM   #9
MLue1
Originally Posted by davserbic View Post
Oooh, I've seen this guy selling this kit for a bit was always curious but never took a chance on it. VERY curious to see what you find.
Lol, our 2.5 engines running so rich installing the Hans turbo probably wouldn't even need much of a tune.
Old 06-09-2017, 03:09 PM   #10
Vikingsloth
Do think I might just be able to use a gti downpipe?
Old 06-09-2017, 03:26 PM   #11
red_stapler
red_stapler's Avatar
Drives: '12 GTI DSG
Maybe? It depends on if that manifold puts the turbo's downpipe flange in the same location as where it would be on a GTI. Unless the turbo is speficially made to match a GTI downpipe, you'd probably have to cut the GTI flange off the downpipe and weld on one that matches the turbo.
'12 GTI DSG
Old 06-09-2017, 03:27 PM   #12
Vikingsloth
All I want is some psssshhhhh
Old 06-09-2017, 03:42 PM   #13
davserbic
davserbic's Avatar
Drives: Golf MKVI
Haha easier said than done with these 2.5's. Have you reached out to Josh Hannabass on Novadubs?
Old 06-11-2017, 01:47 AM   #14
Vikingsloth
No, has good info?
