Old 07-27-2017, 10:22 AM   #15
Steve Lai
Drives: 2012 Golf GTI Mk6 4 Dr DSG
Very helpful. Going to change with the Whiteline bushings to the lower control arm in my 12' GTI. Wonder if the three claw puller is a must coz it appears that the C clamp alone would be sufficed?
I'm going to replace the front busing as well. Any advice on how to replace this piece would be appreciated.
Steve Lai, HK
Steve Lai is offline   Reply With Quote
Old 07-31-2017, 09:06 AM   #16
Steve Lai
Steve Lai, HK
Changed the OEM w a Whiteline bushings. Serious NVH was noted and also squeak noise from the LCA even when parking.
Ref is made to
http://workshop-manuals.com/volkswag...pension_links/
Thoughts ?
Old 08-26-2017, 01:13 PM   #17
Short Bus
Drives: '10 GTI
How did the c-clamp alone work out? Seems like it would be fine if you can use it in a way that allows for clearance so the bushing can come out.
Did you grease up the bushing sufficiently? Poly bushings tend to be really picky about that, which is why I went with the rubber bushings.
