Old 06-15-2017, 11:25 PM   #1
artemk93
artemk93's Avatar
Drives: 2012 KO4 GTI
APR Billet Pendulum Mount VS ECS Performance Pendulum Mount
I already have engine, transmission and dogbone mounts. Want to get the last piece. Trying to decide between ECS and APR.
https://www.ecstuning.com/b-ecs-part...003245ecs03~a/
https://www.ecstuning.com/b-apr-part.../ms100106~apr/
APR one looks a little beefier, but I haven't seen any comparisons between 2 or too many reviews of either piece.
I also doubt that there is a $100 difference between 2.
Any input would be appreciated.
artemk93 is offline   Reply With Quote
Old 06-15-2017, 11:49 PM   #2
Speeddemon69
Drives: 2012 MK6 GTI
APR. I've had problems with a lot of ECS branded parts. Sorry ECS but I've tried to like u, but no success yet.
Old 06-16-2017, 01:42 AM   #3
BudgetPhoenix
Drives: 09 GLI
The 034 is a nice piece for not much money and also offers a spherical bearing
Old 06-17-2017, 11:12 AM   #4
Totally_Stock_Except
Totally_Stock_Except's Avatar
Drives: 2012 Mk6 DSG CW blk roof
After reading that the stock dog bone can break I did this first with the 034 ND the insert, still have stock engine and tranny mounts, car has DSG & 62k mi. Low speed NVH increased, but not sure how much is due to the 034 insert also done at same time. Glad we did it with car up on lift, it's a 4 hands job Lol
Totally_Stock_Except is offline   Reply With Quote
Old 06-18-2017, 10:08 PM   #5
artemk93
artemk93's Avatar
Probably going with 034
Old 06-19-2017, 02:22 PM   #6
TimS
Drives: '12 Golf R
I ran the ECS piece for 30k miles. No issues other than increased vibrations. I switched back to stock to smooth out clutch engagement with the lightweight flywheel and 034 puck mounts.
Old 06-25-2017, 10:45 AM   #7
But the stock pc is still prone to breakage...we still need a stronger pc minus the vibrations ideally. Although I do like how the motor barks to life now when starting Lol.
Old 06-25-2017, 10:52 AM   #8
Interestingly the vibrations only are noticeable under 5 mph...I still have stock mounts and there are no symptoms of thumping or anything to make me think I need upgraded units. I'm at Uni Stage 2 DSG tune, shifts are crisp and quick with the 1+ ECU tune. No vibrations in shifter or sheet metal anywhere when underway.
Old 06-30-2017, 12:11 PM   #9
TimS
Drives: '12 Golf R
Internet forums tend to blow things out of proportion, especially failures like this. How many of the stock mounts have actually broken? Of those failures, how many have been due to the part itself being bad, and how many were caused by abuse and/or mods that drastically changed the way the mount is loaded?
Being stage 1 with stock engine and trans mounts, I'm not worried about the stock dogbone failing in everyday driving. If I ever go stage 2, I'll put the ECS piece back in.
Old 07-09-2017, 04:29 PM   #10
jkells
Drives: 2011 Volkswagen GTI
I have ECS Motor Transmission and Pendulum Mount. And Im definitely a huge fan. I don't get sucked into the 'APR vortex' like most people. Don't pay for overpriced garbage.
Sent from my LG-H910 using Tapatalk
jkells is offline   Reply With Quote
Old 11-17-2017, 03:51 AM   #11
Aphix
Aphix's Avatar
Drives: 2011 2dr 6MT GTI
any update on the ECS pendulum mount? curious how you are liking it.
APR Stage II v2.0 | RSR clutch | Sigma Six SS | TWM Big Type-R | Unitronic CAI | GFB DV+ | Golf R IC | Unitronic TBE | Neuspeed Pulley / TOP / TBP | Soundaktor Delete | HPA (75A) | SuperPro ALK / LCA / RCA | BILSTEIN PSS10 | 034 Strut / Trans / Motor Mounts | H&R 26mm (S) / 24mm (S) | Tyrolsport Subframe Collar / Brake Stiffening Kit / Stage II Aluminum Hatch Brace | R8 coil packs | NGK PFR7B | Modshack trim | OZ Alleggerita | Hawks HPS 5.0 | Michelin PSS
Aphix is offline   Reply With Quote
Old 11-17-2017, 10:29 AM   #12
Jaber
Modero
Jaber's Avatar
Normally I would agree with this, but when it happens to 3 people you know local, it's not worth the risk. $200ish vs $2k in repair damages, I'll take replacing the Pendulum. If you don't accelerate hard from a dig or accelerate hard over bumps/road imperfections, then you're pretty safe.
I have the APR Pendulum and so far no complaints. Works as described and the part/hardware are quality. Really liking my current setup, NVH is bearable (wife doesn't notice unless she is driving). 034 Insert, 034 SD Engine/Trans Mount and APR Pendulum. After all these mounts, car is asking for grip, where as before you felt like there was a delay of power transfer to the front wheels, feels more direct now.
Member Journal
Old 11-17-2017, 11:08 AM   #13
lilonespaz
lilonespaz's Avatar
Thats my setup to once the mounts get installed. 034 motor/trans along with billet insert.
The only thing im going back and forth on is 034/apr pendulum
Old 11-17-2017, 12:06 PM   #14
bart2278
bart2278's Avatar
After all my research I would say APR has the only option that is feasible when it comes to this dogbone/pendulum mount. This is coming from someone that loathes even saying those words as I'm not a fan of the way APR treats their customers. I have tried the torque solutions and it was junk, I'm not even going to sell it to anybody else as I would feel bad. The "Bearing" is a piece of metal stuck in between two pieces of rubber that basically disintegrated after a few thousand miles...maybe. I stuck oem back on, but I will be purchasing APR's when I buy again.
