Old 06-18-2017, 08:28 PM   #1
GTI Mike
Drives: 2012 GTI DSG
Subframe Mount Strength
Hey guys. First time poster, long time lurker here.
I'm planning on upgrading the engine, transmission, and pendulum mounts for my car. If I go stage 2 and go without a torque arm insert, how likely are the subframe mounts likely to hold up? I'm worried the upgraded mounts will put additional strain on the point of least resistance which would be the subframe mounts.
I'm trying to avoid putting a torque arm insert in because of the increased NVH that DSG owners get from it.
GTI Mike is offline   Reply With Quote
Old 06-19-2017, 09:02 AM   #2
lilonespaz
lilonespaz's Avatar
just put a billet 034 dogbone insert in. It will stiffen the subframe mount up easily slides in and only cost like $35
It also doesn't really give NVH. I have it and i maybe notice a tiny bit of shutter when just getting going... nothing with AC on and nothing in reverse etc.
Old 06-19-2017, 09:32 AM   #3
tofuD01
Drives: VW Golf Mk6 Gti
The 034 dogbone insert added alot more idle vibration but mainly noticeable in reverse.
But at speed there's no difference but when gears are changed, it is a bit more responsive.
2010 GTi DSG || APR ECU Stage 2 v2.4 | TCU v1.6 || APR Downpipe || Pipercross Intake || Soundaktor Delete || VWR Springs w/ TT struts || 034Motorsport Dogbone Mount Insert || GFB DV+ w/ main spring || GY Eagle F1 A3 (fronts) || 'R8' Coilpacks + BKR7EIX (0.025")
tofuD01 is offline   Reply With Quote
Old 06-19-2017, 10:02 AM   #4
Corradoluvher
Drives: 2013 vw gti
I noticed a lot of NVH after i installed the 034 pendulum mount and bilet insert. I had the 034 street density engine and transmission mount before i did it. And to me the car feels like its going to stall in 1st gear every time but it doesnt. Its caused by the 034 pendulum mount and bilet insert. I dont mind it. It only feels that way below 1200 rpms in 1st gear. But the car feels great with all the mounts on.
Old 06-19-2017, 11:13 AM   #5
lilonespaz
lilonespaz's Avatar
yeahh i would use the the insert with the APR mount. I honestly think the APR pendulum mount is the best out there.
Old 06-19-2017, 12:15 PM   #6
hbrown0509
hbrown0509's Avatar
Drives: 2013 VW GTI 4DR DSG
What engine and trans mounts are you going with? That'll play a big factor on NVH as well. Inserts help but you will still notice some slop. It takes out a lot don't get me wrong, but depending on your budget a full subframe mount replacement will do wonders. I went with the VWR subframe mount and the vibrations aren't any worse than a poly or billet insert and the shifting with a DSG is crisp.
Old 06-19-2017, 09:04 PM   #7
GTI Mike
I'm going with the 034 street density mounts and the 034 pendulum mount. I've looked into the VWR mounts and HPA puck, but I'd like a less permanent solution for when I sell the car years later.
So far it looks like the 034 billet insert might be worth trying out. I've just been hesitant on getting it since it seems to be the cause of OEM mounts snapping. I assume 034's pendulum won't do the same, hopefully.
Has anyone had any experience with Autotech's insert?
Old 06-20-2017, 08:17 AM   #8
lilonespaz
lilonespaz's Avatar
The OEM mount is cast if im not mistaken which is where the weakness lies. Any aftermarket mount should be able fine. I personally am going with the APR one because it allows the mount to rotate in a different direction then the others to try to avoid sheering the transmission case bolt. Lol i we all my be looking to far into this but ya know.
Old 06-27-2017, 09:55 PM   #9
JT64
Drives: Everything
I started out with an HPA 75 durometer mount and got much less NVH than the 034 one I tried, I'm currently running the above with SPM engine and trans mounts and will be switching to BSH engine and trans mounts and upgrading to an 80 durometer subframe mount from HPA on Friday since my SPM mounts are failing
JT64 is offline   Reply With Quote
Old 06-28-2017, 11:57 AM   #10
GreyGti1990
Drives: 2011 Gti 4-door
I don't think you need to worry about the stock mounts failing from just upgrading some of the mounts and not the others.
I had the VWR upper and lower subframe mounts installed first then almost a year later I did the engine/tranny mounts and in probably another year i'll be doing the pendulum mount.
But the combo I like and will be going with are the 034 street density engine and transmission mounts, the VWR subframe mounts, and the APR pendulum mount. love the 034 mounts and the VWR right now. the engine/tranny mounts are real easy to install yourself.
2011 4-door CSG 6-speed GTi - Sigma Six, Boost gauge, AWE TOP/CTS Throttle, APR Carbonio, Revo 2, GFB DV+, R8 Coils, SB st3 Daily(485ft lbs), VWR FSB, DG Springs, WALK, Front Collar Kit, Fluidampr, APR downpipe, 225/45/17 PSS, Sparco Assetto Gara, Stoptech slotted rotors/pads, Uni Intercooler, BFI Knob, USP SS lines, ATE fluid, Beluga Cat-back, LED Tails.
Soon to Come: Updated Tensioner, Tints.
Old 07-02-2017, 02:56 PM   #11
oracle462
How's the vibrations with the VWR and 034 street?
oracle462 is offline   Reply With Quote
Old 07-02-2017, 05:51 PM   #12
BudgetPhoenix
Drives: 09 GLI
A good amount of people have broken the OEM pendulum mount when using the 034 insert.
