Old 06-18-2017, 09:33 PM   #1
Mk6Daddy
Drives: 2011 Autobahn
Taking in for P2015
Taking the car in for the faulty manifold problem tmrw. Still covered by VW extended warranty and should I expect any grief over intake, exhaust, and a boost gauge installed ?
Mk6Daddy is offline   Reply With Quote
Old 06-18-2017, 09:51 PM   #2
ImitationMan
ImitationMan's Avatar
Drives: 2013 GTI 4Dr CSG
You should be okay. I had my manifold replaced last month and I didn't even change the tune to stock. When I made the appointment, I asked the service rep if it would be a problem since I had tuned the car and had a downpipe and she said it should be fine since its a common part to fail. And it wasn't a problem.
You may want to consider getting a carbon cleaning while they have the manifold off.
APR Stage 2 | Eurojet Catted Downpipe | CEL | IE Cold Air Intake | GFB DV+ | LED Tails | Polar FIS | etc
ImitationMan is offline   Reply With Quote
Old 06-19-2017, 12:42 PM   #3
Mk6Daddy
Ok, thank you.
Old 06-20-2017, 01:46 AM   #4
Blaznjoe
Blaznjoe's Avatar
Drives: 2012 MK6 GTI 2-D CSG
If your boost gauge uses an adapter tapped into the manifold, I recommend removing it. I disconnected/removed my catch can and boost tap to ensure all connections to the intake manifold were stock before taking it to the dealer. Dealer did asked my if I was "modded" and my response was yeah...the intake and exhaust They warrantied my manifold...no issues.
Good luck
2012 MK6 GTI 2-D CSG 6SP-MT
GIAC Stage 2e40|SPM Street DP|SACHS Performance Coilovers|VOLK ZE40's|Neuspeed BBK,Pulley,P-Flo,TOP,FMIC,CBE,SS brakelines,& ShortShifter|Whiteline ALK|Hotchkis F & R Swaybars|Autotech Rotors|Hawk Pads|EuroSport X-Brace|TyrolSport DS SF C Kits|GFB DV+|SB.S2.SMFW|Wavetrac|Michelin PSS|Podi|ECS CatchCan www.kopropo.com/america/
Blaznjoe is offline   Reply With Quote
Old 06-22-2017, 12:03 AM   #5
Mk6Daddy
Good luck
Left boost tap on, no problems. Did manifold, took care of the water pump while there, and did carbon cleaning. Runs great now.
Old 06-22-2017, 12:25 AM   #6
Blaznjoe
Blaznjoe's Avatar
Very nice!
I had exactly the same items taken care of/done since the manifold was going to be removed.
