Old 06-21-2017, 12:44 PM   #1
samcracc
Drives: 13 GLI
GLI be pushed Forward/Back in park (DSG Transmission)
Hello,
2013 GLI here.
My car can be pushed forward and backward (as far as you have the energy to push it) if placed in park.
If you use the parking break, that is the only thing that prevents it from moving.
No transmission codes found using the VCDS.
Car goes into Drive and shift modes fine, but will also not shift into "S".
Any ideas? Thanks in advance!
samcracc is offline   Reply With Quote
Old 06-21-2017, 04:57 PM   #2
Trytun
Trytun's Avatar
Drives: 13 CSG
If it's just a small amount of movement it's fine and normal. Mine does this and so does everyone else's that I've been in. If it just free rolls all over and won't stop then you have a problem. I set my e-brake every time I get out. Not shifting into S though, that's a problem obviously.
Unitronic Stage 2/Unitronic Stage 1 DSG Tune/APR Downpipe/Neuspeed Catback/Miro Shit Wheels/30% all around/Solo Werks S1 Coilovers/TTRS Strut Mounts/Unitronic Intake/Unitronic Intercooler/Soundaktor Delete/GFB DV+/R8 Coils/Spulen Discharge Pipe/Spulen Turbo Muffler Delete/034 Motorsports Billet Insert/034 Motorsports Street Density Motor and Trans Mounts/ECS Tuning Rear Sway Bar THE BUILD THREAD
Trytun is offline   Reply With Quote
Old 06-21-2017, 07:38 PM   #3
samcracc
Drives: 13 GLI
No it is not a little movement, I can move it 10 miles in a straight line if I had the energy. It would indefinitely roll if placed on an incline. It's definitely a problem, and one that I have no clue of where to start.
Old 06-21-2017, 08:03 PM   #4
BudgetPhoenix
Drives: 09 GLI
Can you physically not pull down the shifter in S mode? There's a procedure for adjusting the DSG cable thats pretty simple might be a good place to start.
Old 06-22-2017, 10:33 PM   #5
samcracc
Drives: 13 GLI
Hey I'd love to try this can you point me in the right direction? I searched "adjust DSG cable" but couldn't find anything.
Old 06-22-2017, 11:31 PM   #6
BudgetPhoenix
Drives: 09 GLI
Large image of the procedure from the Bentley manual
http://imgur.com/a/5nZ3v
