Old 06-26-2017, 06:44 AM   #1
rmetanes
Drives: 2012 MK6 White GTI
Error code P0172 - PLease help
Hello
Ive been having error P0172
system bank 1 too rich
I got some logs from the Torque application today
CAn some one tell me what is wrong with my 2012 GTI ?
Mode $06 report generated by Torque for Android
Vehicle VIN: WVWZZZ1KZCW270343
Vehicle Manufacturer: Volkswagen
Vehicle Calibration ID: 5K0907115
0050
Test report:
MID:$01 TID:$43
- O2 Bank 1 Sensor 1
Max: 0 Min: 1,033.70007
Test result value: 3,417.6001
FAIL
MID:$01 TID:$83
Max: 1.99882 Min: 0.3499
Test result value: 1.21195
PASS
MID:$01 TID:$84
Test incomplete or dependant test failed
MID:$02 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 2
MID:$02 TID:$81
Max: 0.6305V Min: 0V
Test result value: 0.62074V
PASS
MID:$02 TID:$82
Max: 1.26002V Min: 0.6305V
Test result value: 0.64026V
PASS
MID:$02 TID:$86
MID:$0f TID:$83
- O2 Bank 4 Sensor 3
Max: 531.82001A Min: 225.53A
Test result value: 591.39001A
FAIL
MID:$21 TID:$84
- Catalyst Monitor Bank 1
MID:$35 TID:$80
Max: -4 Min: -20
Test result value: -10.56
PASS
MID:$35 TID:$81
Max: -4 Min: -20
PASS
MID:$3d TID:$80
- EVAP Monitor (0.020")
MID:$3d TID:$82
Max: 9.99393 Min: 0.06954
Test result value: 0.07076
PASS
MID:$41 TID:$85
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 1,239.90002C Min: 754.90002C
Test result value: 820C
PASS
MID:$42 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 1,682Ohm Min: 0Ohm
Test result value: 124Ohm
PASS
MID:$81 TID:$45
- Fuel System Monitor Bank 1
Test result value: -3,136
FAIL
MID:$82 TID:$cd
- Fuel System Monitor Bank 2
Max: 204.79999A Min: 62.16A
Test result value: 655.20001A
FAIL
MID:$9f TID:$66
Max: 53,131 Min: 22,553
Test result value: 51,939
PASS
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
Test result value: 1Count
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
Test result value: 2Count
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$cf TID:$9c
Max: 53,162 Min: 22,553
FAIL
MID:$df TID:$b1
Max: -37.68304% Min: 68.83176%
Test result value: 16.95386%
FAIL
End of report.
rmetanes is offline   Reply With Quote
p0172
