#21 | |
![]() Drives: k04 GTI Join Date: Sep 2009
I understand how a catch can works. If you look at my build thread you'll see that I've had one installed since practically day one. And I had one installed on my previous car too. Mainly, I'm curious about the oddly shaped piece of metal that came with the kit. |
#22 |
![]() Drives: Join Date: Aug 2008
Not yet. I still need to write them within the next couple of days.
The process is very simple. The most difficult/time consuming part is the removal of the noise pipe and its support bracket to make room for the tank. Once that's out of the way, it's bolt-on and go.
Forge Motorsport - 407-447-5363 sales@forgemotorsport.com YouTube |
#23 |
There are a couple installed photos floating around already that I have posted before.
#24 | |
![]() Drives: 2010 MKVI GTI Candy White Join Date: Mar 2010
Any chance there will be pricing and availability before Mrs. Bender starts to do her Santa Claus thing?
http://www.VAGer.org 2010 Candy White GTI - GIAC Stage2 Courtesy of AWE - AWE TOP w/ S3 Intercooler and AWE hose kit - AWE CCB - AWE Turbo Back Exhaust - Clutch Masters FX400 8 Puck - BFI Stage 1 Mounts - 28mm Front H&R Sway Bar (Soft) - 24mm Rear H&R Sway Bar (Stiff) - Unibrace XB and UB - Driver's Gear Springs - StopTech Pads - USP Motorsports Stainless Steel Brakelines - 35% Tint - Tinted Footwells - Interior LEDs - Smoked Side Markers - Blind Spot Mirrors - Man this is getting long Bender's Build Thread Good cop and bad cop have left for the day. I'm a different kind of cop. |
#25 | |
#26 |
Since a lot of people have been asking for more details on the "Africa plate".....
The outlet fitting is strategically positioned on the "Africa plate" at an ideal pickup location to draw out the crankcase pressure. It is positioned directly over a baffle/splash shield already integrated into the OEM valve cover that will minimize the pickup of liquid oil, and ensure that only gases and vapor are drawn into the tank. ![]() ![]() The fan shaped cutout is a functional feature that allows the crankcase pressure from the lower portion of the block to merge and equalize with the pressure in the head/valve cover. It only requires that a small portion of the OEM PCV gasket be trimmed to accomplish this. This is normally done within the upper portion of the OEM PCV assembly in a complicated mess of check valves and channels, but we simplify the entire setup and keep all of that function hidden underneath the slim profile of the "Africa plate." ![]()
#27 |
![]() Drives: CW MK6 GTI, Manual Join Date: Nov 2009
Very interesting! Waiting for pricing..
*** M Y - P R O J E C T*** |
#28 |
![]() Drives: UG MK6 DSG APR Join Date: Nov 2009
Waiting for price. Subscribed.
#29 |
Price? And where to buy?
#30 | |
![]() Drives: 2011 GTI Join Date: Sep 2010
#31 |
![]() Drives: 2010 CSGTI Join Date: May 2010
Must you remove the noise pipe? What if someone plans on using it for a DV relocation in the future?
And is there going to be any way to fit the tubing through the stock cutout? Last edited by DubbinIt; 11-09-2010 at 11:39 PM. |
#32 |
![]() Drives: MKVI GTI Join Date: Oct 2010
Forge said it will not fit the stock cut out unless you place the catch can on the right side (no space). I even asked this question and they said they made it that way since it looks better. I personally would want to use the stock cut out, but unfortunately it doesnt.
#33 | |
Rather completely redesign a new smaller tank for the TSI motor, which is still within the same engine bay as a MK5 with an FSI motor, and since most people want the largest possible tank they can get anyway, we chose to remove the noise pipe. We are looking into potentially offering our own valve relocation setup soon that will utilize a flexible return hose that can more easily be routed out of the way rather than a rigid hard pipe that is takes up otherwise usable space. Right now, the supplied tubing will not extend through the cutout in the stock cover. You will need to make a small relief hole in the cover or use your own supplied longer tubing.
#34 |
To make way for my BSH catch can, I actually modified the entire front of the engine cover. Take a look at my build pics and you'll see what I'm talking about.
It gives the engine cover a much more symmetrical appearance. |
#35 | ||
#36 |
![]() Drives: '10 GTI DSG+APR S2 Join Date: Aug 2010
#37 |
#38 |
If either of you were serious about having a cc, then you wouldn't let this bother you.
#39 | |
Say what...?
FYI I am serious about a "cc" and I would like it to fit without any cutting. As Forge Mike said: It would work at stock cutout location if I "use (my) own supplied longer tubing". IMO it looks alot better and functions just as well using the stock cutout location. Just because the OP decided to cut his own hole doesn't make me any less serious because I don't want to cut mine. Summary: A nice looking product that would be alot nicer if it fit without cutting the expensive engine cover. Peace '83. Last edited by burtomr; 11-10-2010 at 09:30 PM. |
#40 |
dsm, maybe people dont want be cutting through there engine cover. Ever think about that? its not a matter of functionality, its a matter of aesthetics. Not everybody is a hardcore racer like you.
| Thread Tools | Search this Thread |
| Display Modes | |
