Old 07-07-2017, 08:41 PM   #1
R35Dan
Drives: 2012 MK6 GTI
Stock to HPA K04 w/E85
Hi everyone,
Picked up my first GTI recently.
To make this short it ended up needing a new engine. There is a thread in the maintenance section on everything if anyone would like to find out more.
The following is going to be done in addition to the brand new engine.
Can't wait to get it back, should make for a fun daily. I'll update the thread with more when the time comes.
  • HPA Hybrid K04 Turbo kit w/ GFB DV+
  • Catless 3" Downpipe w/ o2 spacer
  • Catback Exhaust
  • Cobb Big SF Intake
  • Cobb V3 AP w/Stratified Pro-Tune for E30 mix and pump 93
  • R8 Coils and NGK Spark Plugs
  • All Fluids changed to Motul
  • Rotors, Pads, and Wheel Bearings (courtesy of the Dealer)
Size:  28.1 KBName:  unnamed (2).jpg
R35Dan is offline   Reply With Quote
Old 07-07-2017, 10:12 PM   #2
whitewolf33
whitewolf33's Avatar
Drives: 2013 CW Wolfsburg
Looks you have a lot planned. Where in NY?
Old 07-07-2017, 10:44 PM   #3
mostic
mostic's Avatar
Drives: VW
It seems that
Old 07-07-2017, 11:30 PM   #4
riceburner
Drives: 2012 GTI DSG / K04
nice! turbos and e85 go together like peas and carrots.
what are you doing to the physical fuel system though?
Old 07-08-2017, 06:32 PM   #5
R35Dan
Rochester
I will be going with the advice of the tuner as far as fuel goes. I believe I can stay stock with e30-50 mix. If not I'll figure it out.
Old 07-27-2017, 11:25 PM   #6
R35Dan
Got the car back earlier this week. So far so good, the car feels great.
I put a hundred miles or so on it and did the logs for Alex at Stratified. Just waiting on him to get back to me with revisions/fine tune the car on 93...Then onto E85 Mix
Will upload some pictures/videos when I get a chance.
Old 08-04-2017, 12:11 PM   #7
R35Dan
Looks like the HPA turbo kit has a soft wastegate. The solution is to install a Forge actuator with their yellow spring. As for fueling the car is set on the stock setup.
I'm going to continue breaking it in and then finish off refinement.
https://gyazo.com/413d0807dc91faad3670e5b3d61309fe
https://gyazo.com/77f8e5a756688c532176d8aed3c910b3
https://gyazo.com/77e857cfae06394d3d075983f38fb031
Old 08-04-2017, 01:23 PM   #8
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Soft in what sense. What kinda boost you trying to push? Should certainly hold 23psi at least.
Old 08-04-2017, 02:41 PM   #9
ahard48
ahard48's Avatar
Originally Posted by R35Dan View Post
Rochester
I'm excited for you and this car. I'm in Rochester too, hope to see this on the road!
2014 GTI Wolfsburg:
Old 08-06-2017, 11:31 PM   #10
Dasteknoviking
I ran E85 tune on my stock IHI turbo, but in all honesty there is no more power left in a K04 TSi. She's maxed out on 93/100 octane fuel. You also might be hitting your torque limiter on a stock Dsg trans.
I have a 09 SportWagen 2.0T TSi CCTA with charge pipes, CTS turbo K04 kit, CTS turbo DV (GFB I did not like), Jetex 3" exhaust with a 200 cell cat and 42DD spacer. Forge Twintake and Neuspeed front mount intercooler. I have issues with hitting my torque limiter on the Dsg. I would recommend getting a tune for it. I'm going with United Motorsport for that. I run a DriverMotorsport engine tune (I think they are out of business now). Car puts down some very serious power, looking at my MAF sensor g/s she should be making in the area of 350-355whp. I run 29psi of boost daily, have been for the last 45k miles.
Unfortunately Cobb doesn't make a tuner for the mkv. But that's OK, Maestro is boss if I choose that route when I do internals and a large frame turbo
Sent from my Nexus 6 using Tapatalk
Dasteknoviking is offline   Reply With Quote
Old 08-10-2017, 10:52 AM   #11
R35Dan
The wastegate is soft based on multiple logs. The boost is not consistent. Tuner's advice is always the best imo.
Thanks! See you around
Update: Turbo needs to get pulled to install the wastegate
It's a real love and hate relationship with this car right now.
Old 08-10-2017, 12:22 PM   #12
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Oh upgrated wastegate or oem replacement?
Old 08-11-2017, 06:14 PM   #13
Dasteknoviking
Well if you have small hands and access to a lift Forge wastegate can be installed on a TSi with a K04. I loosened all my bolts, and then ran out of time and put it back on. I ended up selling that actuator, new in a box. I heard from my tuner that it was a mofo to tune it right and it was a waste of my time and money.
Old 08-13-2017, 03:09 PM   #14
R35Dan
It's a Forge K04 Wastegate with the yellow spring (10-15psi)
Yep neither myself or the guy at the shop have small hands. Were bigger guys.
Upgrading a wastegate on any car isn't a bad idea if the one on their isn't working. Not sure how it would be difficult to tune, can you explain? Who is the tuner?
