Old 07-11-2017, 08:36 AM   #1
50Fathom
Drives: 2013 Golf R
Clutch pedal bypass
I installed a harness to bypass having to press the clutch pedal to start the engine, while I like the mod, I do not like looking at the little message to "Depress clutch pedal to start" on the DIS once you put the ignition on.
I unchecked byte 20/bit 4 of the 09/central elec module to disable the Interlock Display ("Press Clutch") in instrument Cluster active but the message is still there. Is there anything else that needs to be changed to get rid of the startup message?
50Fathom is offline   Reply With Quote
