To speak to the orignal thread question about wheels sizes and lowering cars "slightly" I wanted to share my experience.
I did thorough research into my combination of wheels, tires, and suspension setup to ensure I wouldn't have clearance issues (rubbing).
Well, after hearing people give testimony after testimony (even seeing that same chart above posted over and over again in different threads, even on different forums), I purposefully chose the least aggressive/least evasive setup to ensure I did not push the limits.
The choice: 18x8 ET45 w/225/40 Michelin PS2s + Neuspeed Sport Spring + Koni FSD shocks.
The result: RUBBING!
You are a great help to many for speaking out. As I posted just before the chart, the 18" x 8.5" ET 45 is clearly not flush. Many say they run that size without issue, but how can that really be true considering the wheels are outside of the fenders. It just doesn't make sense.
I have seen that size wheel with the tires tucked under the fenders, but they must be running excessive negative camber to get them under the fenders. There are also guys doing fender pulling, tire stretching, and whatever it takes to get the tires under that car. It is a bit ridiculous, even though it looks cool.
I decided not to go with the Interlagos, 18" x 8" ET41, because of the front poke. Many seem to run the set-up, but I do not want poke. I thought 18" x 8" ET45 might be OK, although it was a little too close for me. I am going with 17" x 7.5 ET47. I'm very confident I will be fine, even after going lower.
I'm sure you are a great guy and your car is probably gorgeous, but I doubt that is true.18" X 8.5 et. 35 is pretty flush front and back if ur going for that
