Old 07-16-2017, 10:27 AM   #1
ZERFLO
ZERFLO's Avatar
Drives: Black 2012 Golf MKVI
Quick help! 2.5 losing power
Sup guys... here's the quick story.
2.5 Stock MK6 with 112k miles losing power driving down to LA from SF
All services done, engine, trans.
Right about the Grapevine a the top of the hill it started to loss power after a great starting of the trip.
80mph are pretty normal up there and it was 100 degrees outside.
I had to pull over on a rest area since I couldn't keep up driving 50mph.
No lights on the dashboard ever. Got out turned it off and did a restroom trip and got back in the road like nothing happened.
What could it be. I'm afraid that this will happen in the way back.
Thx in advance.
ZERFLO is offline   Reply With Quote
Old 07-16-2017, 04:38 PM   #2
MLue1
Since you're climbing hills and 100 degrees F. I think it maybe knock related or vapor related or a combination. I read an old thread where the 2.5 ECU will dial the ignition timing back (retard) the timing by a significant amount when knock is detected. In that case it takes a long time for the ECU to normalize maybe in a protective mode, by turning off it resets the ECU.
It could be vapor lock, especially if your using a gas with ethanol.
https://en.m.wikipedia.org/wiki/Vapor_lock
If you're not using 91 octane you should get some or use a fuel with no ethanol.
Good luck
Old 07-27-2017, 11:26 AM   #3
ZERFLO
ZERFLO's Avatar
Good luck
Thx for the help...
Car behaved normal after that and showed no problems since even in the way back... it was not as hot tho.
It could be the fuel since i haven't been driving the car ok the and my wife or my sister share it sometimes so they're responsible for the kind of gas pumped. I will ask.
Thx again.
Old 07-27-2017, 02:46 PM   #4
MLue1
Thumbs up
Thanks for closing this off properly! Under extreme conditions it maybe a good idea to use a higher octane gas.
Here is a list of past Threads on Ignition Timing and Octane:
http://www.golfmk6.com/forums/showth...gnition+timing
http://www.superstreetonline.com/how...-jetta-proven/
