Old 07-20-2017, 07:00 PM   #1
josueleon89
josueleon89's Avatar
Locked up engine
I was driving off a ramp and by mistake I pressed the gas all the way to the ground and the revs went all the way to the red numbers. So when I stoped to turned the car had already cited off so I tried to started again but all it does it's a click sound. So I need some help on wether buying a used one which I got a quote and it's 2700$ or maybe just go under the carter take it off and replaced the crankshaft metals if the crankshaft it's not mess up.
josueleon89 is offline   Reply With Quote
Old 07-20-2017, 08:47 PM   #2
Nezoid
Drives: F23T DSG 2010 GTI
josueleon.. really hope you get the help you need. And I'm going to try and translate as I'm sure autocorrect is a bitch.. I'm guessing you have a 6mt.. and you were coming off/on the off/on ramp, and were in to low of a gear and redlined (7000+) the engine..
I don't have a standard GTI(you could have a dsg) so I can't compare.. but I'm guessing if the 6mt doesn't have overrev protections.. you could have toasted the motor..
Now after that.. I'm at a loss. What are you trying to figure out if buying what? You got quoted $2700.. for what? engine replacement? transmission replacement? Crankshaft "metals" replacement?
With the symptoms you've stated.. it could be a dead battery.. but giving the circumstances I doubt that is your issue.
I know you're in a crappy situation.. but the more information you give the forums.. the more they can help... Sounds.. Pictures.. anything... Provide a picture of the quote being done on your car.. anything. I'm sure there are plenty of people wanting to help..
Just try not to let autocorrect type your post, because it is difficult to read.. Either way GL.. Hope it isn't serious..
Nezoid is offline   Reply With Quote
Old 07-21-2017, 09:34 AM   #3
damagi123
damagi123's Avatar
Drives: 2012 GTI DSG
your post is a mess so its hard to tell whats what but the manual has a fuel cutoff at 6800 or 7k I think if its tuned. You cant have over revved once and blown the motor unless theres something else going on here. Did you keep it at redline for 20 minutes straight? Are you tuned? Disabled rev lmiter? were you having timing problems and or was there oil in it lol? we want more deets here
Originally Posted by Nezoid View Post
lol i love the idea of an all ebay GTI great job
Old 07-21-2017, 11:40 AM   #4
thatspsychotic
thatspsychotic's Avatar
You may want to try again with language that is more clear and detailed.
Take the thing to a mechanic. Could be something as simple as a coincidental starter failure, but if you were driving really fast around the corner and also redlined it, there's a chance that it got oil starved from the hard cornering and could have burned all the bearings even if the revs were limited to 6800 RPM by the rev limiter.
Present: APR Stage 1+ v2.4 | APR Carbonio | R8 Coils | GFB DV+ | Unibrace UB | Tyrolsport Deadset | SuperPro Offset LCA Bushings | Enkei Raijin Gunmetal 18x8 et45 | Michelin PSS 245/35R18 | NewSouth Perf. Mech Boost Gauge
Future: ST Coilovers | H&R 26/22mm Swaybars | APR/ECS Catch Can
Old 07-22-2017, 12:59 PM   #5
josueleon89
Yes I did had it around 7k revs for about 4 secs, and a trying to avoid taking it to the shop unless it's the dealer but now I know it is the engine cause I took off the belt and try to give it a few turns to the main pulley and it wi not go any where. Am pretty sure the bearing are melt it to the shaft
Old 07-22-2017, 01:01 PM   #6
josueleon89
I just can't believe that VW engines are so delicate, I had a Nissan 95 Altima and had rev. It almost to the max a few times and never gave a problem.
Old 07-22-2017, 01:02 PM   #7
josueleon89
The cheapest engine price I found it's 2700$ !!!!! Why am never buying VW ever again. Das auto !!!!
Old 07-22-2017, 01:12 PM   #8
FocalPoint
FocalPoint's Avatar
Drives: MKV GTI/MKVI GTI
That's reasonably priced, considering this issue is a direct result of your actions.
Old 07-22-2017, 04:30 PM   #9
BudgetPhoenix
Drives: 09 GLI
A modern engine toasted after only 4 seconds of redlining it? Did it have no oil? I feel like there must be another issue.
Old 07-22-2017, 05:11 PM   #10
c72k
Drives: Mk5 GTI Fahrenheit
This. Plus, it would help if the OP could compose a response better than first grade level.
c72k is offline   Reply With Quote
Old 07-23-2017, 12:40 PM   #11
iGTI
iGTI's Avatar
This is odd because there's s fuel cut off point on manuals... I accidentally did slammed it once to a low gear, in which it would cause a over-rev but the fuel cut off saved my ass. Best wishes, maybe it was just bad luck on your part.
On another note you can't say your disappointed on vw for having a "delicate" engine. You made a mistake that engine didn't have a tolerance for, end of story.
S3 16'
STG 1+ Sold
Old 07-23-2017, 01:01 PM   #12
1ashchuckton
1ashchuckton's Avatar
Even though there is a fuel cut off if you drop into a low gear at too high of a speed you will over-rev your engine. Quite possibly causing some ugly & costly damage. This is known as the money shift.
Old 07-23-2017, 03:30 PM   #13
josueleon89
100% it's my fault, but I have owned chevys and Nissan and quit few times I took them to the test rev the engines at red for a few secs and never had this problem, I think vw does make fancy and performance cars but they r using cheap metal material where they really to use a decent material, but any who am ever since I bought it pre owned from vw I always had problem with it, like coils, battery, HID lights, the headliner, an engine light keels beeping every time I drove it in city, maybe it's me that am just having bad luck
Old 07-23-2017, 06:18 PM   #14
FocalPoint
FocalPoint's Avatar
