Old 07-26-2017, 02:24 AM   #29
iGTI
iGTI's Avatar
S3 16'
STG 1+ Sold
Old 07-26-2017, 09:10 AM   #30
OEMPL+S
OEMPL+S's Avatar
Drives: 11' A3 T Quattro ScubaBlue
Get someone to read your ecu .... With a OBD scanner .... The ecu should have logged what happened .... Just that's what I've heard of people doing before when there engine kicks the bucket for no reason.
All cbfa engines should fit your cbfa engine vehicle ..... I may be wrong
Sent from my XT1635-02 using Tapatalk
OEMPL+S is offline   Reply With Quote
Old 07-26-2017, 10:21 AM   #31
1ashchuckton
1ashchuckton's Avatar
so I was on my phone distracted
Now I understand.......
Old 07-27-2017, 11:22 AM   #32
josueleon89
josueleon89's Avatar
Does any one knows of a video on how to remove engine from 2010 gti? And what would be the best cheapest diagnostic code reader For vw ?
josueleon89 is offline   Reply With Quote
Old 07-27-2017, 11:23 AM   #33
josueleon89
Originally Posted by BudgetPhoenix View Post
A modern engine toasted after only 4 seconds of redlining it? Did it have no oil? I feel like there must be another issue.
It sound weird and odd but it happens.
Old 07-27-2017, 12:29 PM   #34
OEMPL+S
OEMPL+S's Avatar
For a code reader: OBD eleven .... And buy the app as well .... Or just get it scanned at a pro shop
Old 07-29-2017, 06:45 PM   #35
josueleon89
[quote=OEMPL+S;2542542]For a code reader: OBD eleven .... And buy the app as well .... Or just get it scanned at a pro shop
Sent from my XT1635-02 using Tapatalk[/QUOTE
Not just for codes reader, I need one that will diagnose any problem with my car.
Old 07-30-2017, 05:33 AM   #36
realcyberbob
realcyberbob's Avatar
Just get Vagcom.
Old 08-05-2017, 10:03 AM   #37
FocalPoint
FocalPoint's Avatar
Drives: MKV GTI/MKVI GTI
I would highly recommend having a professional do this repair. As far as video DIYs on how to remove a Golf R engine, I think you're out of luck, although self explanatory. You'll need to support the engine from underneath with either a hoist or jack, properly cap off or drain coolant and oil feeds and remove from block. Unbolt transmission case and internals from the block, then do mounts last. Obviously it's way more complicated than this brief description, and requires a good idea of how everything works and where everything is placed. To do this in my own personal garage would probably take a week(s) just to get the thing out of there. A shop would have it out in a day or two.
Old 08-11-2017, 10:17 AM   #38
thatspsychotic
thatspsychotic's Avatar
Originally Posted by josueleon89 View Post
The engine had oil, always check it every month.
Being as little as 1 quart low caused my low oil emergency warning to beep at me during hard turns in an autocross run. I wouldn't rule out high-RPM oil starvation if you were going around a corner on an offramp. If that's the case the motor is toast.
I went all thru the red line for about 3 to 7 seconds.
First, do you mean all the way through redline as in showing 8k RPM? How did you keep your foot on the gas for that long without noticing?
And after that, the engine cut off. My engine it's stock. I have not touched the rev limiter.
If you haven't touched the rev limiter, it should never exceed 6800 or 7100 RPM depending on the factory rev limiter. If you saw something beyond that, the only way it could get there is if you money-shifted into too low of a gear and just haven't told us that yet.
See if my car was just sitting at the house iddiling and I would floor it by mistake it will only go to probably 3500 rpms or so. It will not go all the way to the red line. But if I was on the highway and set it on neutral and floor it it would of go all the way to the red line
That's the factory ECU doing its job. No rev limiter will prevent the revs from going to the moon if you downshift into an inappropriately low gear. Honestly, that's the only thing that would make any sense at all here, but you haven't volunteered that story yet.
Present: APR Stage 1+ v2.4 | APR Carbonio | R8 Coils | GFB DV+ | Unibrace UB | Enkei Raijin Gunmetal 18x8 et45 | Michelin PSS 245/35R18 | NewSouth Perf. Mech Boost Gauge | Soundaktor Delete
Future: ST Coilovers | Tyrolsport Deadset | H&R 26/22mm Swaybars | MOOG End Links
Old 08-26-2017, 03:44 PM   #39
josueleon89
Well I sure appreciated all the comments. Just wish me luck cause I bought an engine from ebay that cost $1700 which to me it's pretty cheap, 110k miles according to the guy, my main concern it's if the engine has been used really aggressive, but hopefully not, and swapping the engine this. Weekend, I noticed that it's pretty easy compare to a V8 crown Vic. Wires and confections and room wise.
Old 08-26-2017, 03:52 PM   #40
josueleon89
For those guys that are pro at VW u might me wondering why I dropped the tranny too, reason is that since my engine it's locked up, I had no way to turn the engine to unbolt the flywheel from the engine
