Old 10-04-2017, 12:29 AM   #281
Stock-GTI
Stock-GTI's Avatar
Drives: 2013 MK6 GTI
Originally Posted by mk6'12gti View Post
Grams put the throttle bodies on back order supposedly they are "reprogramming" them. Honestly them saying it's plug and play and no tune required is kinda horse shit if you ask me.
Idk, at this point I might put the stock TB back on because my driveability is horrible surges like hell at low speeds, mpg crap, fuel trims etc. I commute 80-100mi a day, can't keep driving like this lol. Gonna check all the connectors one more time. I really doubt it's my tunes fault, since several people are running it perfectly fine with an aftermarket tune. And I want to get my stratified protune going. I.E. Manifold provides more than enough flow anyways.
Old 10-04-2017, 12:32 AM   #282
Speeddemon69
Drives: 2012 MK6 GTI
damn weird that some people are having issues with the new TB... can you explain in exact detail the surging your experiencing? are you dsg?
Old 10-04-2017, 01:08 AM   #283
Stock-GTI
Stock-GTI's Avatar
Yeah im dsg, it feels like since the adaptation fails, the TB is either shut or wide open. At low speeds the car bucks, and acceleration is choppy, 0-35 mph is hell. I also can hear the car bleeding off the excess boost. Cars also running rich to compensate.
For perspective my mod list (eventually gonna make a thread after i'm tuned and this crap is sorted out):
Cobb Tuning AP3-VLK-001
Cobb Tuning Downpipe Non-Resonated
Cobb Tuning Catback
Integrated Engineering Cold Air Intake
Integrated Engineering Intake Manifold
Spulen Turbo Muffler Delete and Boost Pipes
Fluidampr + ARP Bolt Kit (Crank Pulley)
ARM Motorsports FMIC + Stock IC Delete
Grams 70mm Throttle Body
R8 Coilpacks
NGK BKR7EIX (2667) Spark Plugs Set (4)
Gruven Billet Pulley Set (Alternator and Tension)
Port and Polished Stock Turbo (IHI RHF5)
Forge Wastegate Actuator
GFB DV+
PTP Lava Wrap on Downpipe
PTP Turbo Blanket
Currently running Cobb Stage 2 Stock MAF 93 oct.
Attempted to run the first revision of my stratified map, but anything above ~30-40mph causes overboost and limp mode.
I know someone who ran the TB with I.E manifold and they have 0 issues. And yes I realize in this setup the turbo is now the restriction.
Old 10-04-2017, 01:09 AM   #284
mk6'12gti
Drives: 2012 4dr Black Gti
I remember Peter from IE said this about it running on a tune not ment for that tb. "The throttle control on the ecm side will be all screwed up till a turner fixes the mapping for the larger tb."
Old 10-04-2017, 01:14 AM   #285
Stock-GTI
Stock-GTI's Avatar
Yeah I'm sending a email to my tuner at stratified to see if they can fix the problem. They're past the 48hr respond period from my previous email though.
I really don't want to take off the TB, but I might have no choice for now.
Old 10-04-2017, 03:44 AM   #286
mk6'12gti
Yeah, it feels like since the adaptation fails, the TB is either shut or wide open. At low speeds the car bucks, and acceleration is choppy, 0-35 mph is hell. I also can hear the car bleeding off the excess boost. Cars also running rich to compensate.
Cobb Tuning Catback
R8 Coilpacks
GFB DV+
PTP Turbo Blanket
Any real benefit with the gruven pulley set?
Old 10-04-2017, 07:36 AM   #287
Stock-GTI
Stock-GTI's Avatar
Hard to tell with the throttle issues at the moment, but from what I can tell revs are definitely smoother and lighter. I attribute the smoothness to the fluidampr, but the reduction in rotational mass is nice. I know the stock turbo can only flow so much, so I'm to trying to gain back lost hp rather than create more.
Old 10-04-2017, 11:16 PM   #288
A3Scott20
A3Scott20's Avatar
Drives: 2013 A3 DSG
Currently running Grams TB together with IE intake manifold and no issue. Low end torque and throttle respond are better
BTW, I have had to make another new throttle pipe in order to avoid collision between throttle pipe and fans, because car has APR intercooler and TyrolSport radiator installed, that means the space is really limited.
A3Scott20 is offline   Reply With Quote
Old 10-05-2017, 12:17 AM   #289
Stock-GTI
Stock-GTI's Avatar
Yeah I know lol, I'm the one who messaged you on IG. Grams said they want the TB back for testing and are sending me a return label, I'm trying to get them to send me a replacement first because I don't want to have to put the stock one back on, but the car is my daily so I might have no choice.
I'm using USP's Spulen Throttle pipe still have pretty ample space.
Old 10-05-2017, 02:02 AM   #290
Speeddemon69
good to know i'm not the only one having this problem.
Old 10-06-2017, 06:11 AM   #291
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Same issue here, had to bend the Nuespeed TBP bracket which bolts to the block, this gave me some clearance again between the fan and TBP.
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 10-07-2017, 02:47 PM   #292
Chris659
Drives: 12 Beetle Turbo
I've got their idler pulley on mine. Can't say I noticed any difference but any time I can swap out factory junk for quality parts I will. I've heard bad stuff about the alternator pulley since it's clutchless though
Old 10-07-2017, 07:19 PM   #293
Stock-GTI
Stock-GTI's Avatar
I've heard both ways. Tried to find the thread I read somewhere clutched pulleys are more important on Diesel engines due to increased vibrations. I'm monitoring battery voltage and other parameters, and my belt for wear. If I get any sign of a issue the stock one goes back on. Haven't noticed any increases in NVH. That being said I would never install the idler or Alternator Pulley without having a fluidampr as well.
Sorry for derailing the thread. I'll update if I find that the Grams TB was faulty.
Old 10-09-2017, 08:52 AM   #294
jkells
Drives: 2011 Volkswagen GTI
I would check to see if you have a boost leak. I had a leak at the connector to the TB. You literally have to seat the flange on the TB all the way at the top and torque it down EXTREMELY tight with a ratchet. I have not had a single issue since I did that.
jkells is offline   Reply With Quote
grams, throttle body, throttle body upgrade
