Old 08-06-2017, 11:42 PM   #1
jsparr123
Drives: GTI
DIY for upper timing chain cover?
Car was recently at dealership for some recall work and the tech noted that there appeared to be oil leaking from around the upper timing cover, so I was just wondering if anybody had a DIY for changing the upper timing cover gasket?
jsparr123 is offline   Reply With Quote
Old 08-07-2017, 04:06 PM   #2
sauceman101
sauceman101's Avatar
Drives: 2010 UG GTI 6MT
Should be in the haynes manual. 5 bolts come out plus the magnet sensor on the end of the intake cam, replace gasket, installation reverse of removal. Don't know torque of the bolts, and or if there is an order for torquing. Kind of don't think so, bottom 2 of 5 can be a bitch to get at
2010 UG GTI 6MT: Peloquin LSD, APR Stage 1, DIY RSR Clutch, VWR Streetsport+ Coils, IE Camber Plates, 034M Front End Links, Hotchkis RSB, APR Stage 1+2 Carbino Intake, HPA Red Subframe Puck, Enkei PF01s wrapped w/ Star Spec 2s, AWE DP, [i] Magnaflow CBE, BIG things coming if you catch the drift
sauceman101 is offline   Reply With Quote
Old 10-24-2017, 01:25 AM   #3
tech54K
Drives: Refurbished
thanks for the DIY!
tech54K is offline   Reply With Quote
