Old 08-08-2017, 12:55 PM   #1
onecrazyfuq
Drives: 2013 VW MK6 Golf 2.5 Auto
Warm starting issues. HELP NEEDED!!!
I have a 2013 2.5 Automatic golf with approx 66k. Recently whenever I have issues starting the car after it I have turned it off and it sat for approx 10 minutes. When I start it in the morning no issues, but if i stop at a store and go to start up again the car will not start unless I give it a little gas. The car also makes a surging sound for a moment after starting. I have replaced the fuel filter along with the air filter. It seems to be a warm start up issue. No codes have been thrown. All advice is appreciated. Thanks in advance. -Anthony
Sent from my SM-N920V using Tapatalk
onecrazyfuq is offline   Reply With Quote
Old 08-08-2017, 02:37 PM   #2
MLue1
I have heard about this problem, even experienced it on cold winter mornings but never had any problems when the temperature is over 40 degrees F. When it's really cold I don't dare turn it off until I've driven for 10 minutes.
When last was your car serviced ? You should try cleaning your throttle body (butterfly valve and the barrel), with a can a carb cleaner and some paper towels; then do a throttle body adaption. If you take it to a Mechanic chances are he will do the same steps.
https://youtu.be/41yFXjibtLY
https://youtu.be/fdLA5pXUkk4
MLue1 is online now   Reply With Quote
Old 08-08-2017, 10:13 PM   #3
onecrazyfuq
It happens regardless of temp. If drive it around for a while and turn it off briefly as soon as I attempt to turn it back on it gives me a hard time starting unless I give it some throttle. It would be so easy to diagnose if it would just throw a code.
Old 08-10-2017, 07:02 PM   #4
Staver
Drives: 2012 MKVI Golf - 2.5L
any luck? It couldn't be bad spark plugs or something like that? Or maybe you are running rich in terms of your fuel mixture.
I saw a few posts on other boards where this kind of symptom was linked to the fuel system where things weren't shutting off properly and things were getting slightly flooded. But those were on older VWs.
Mark
Staver is offline   Reply With Quote
Old 08-14-2017, 03:31 PM   #5
onecrazyfuq
Mark
No luck so far. I haven't changed the spark plugs yet because the car is completely fine when it's up and running. I just have to give it gas to start when the car is warm
Old 08-15-2017, 08:43 AM   #6
MLue1
....Or maybe you are running rich in terms of your fuel mixture.
Good suggestion !
I know in the winter that seems to be the case if you turn off the engine before it warms up, it's a bugger to get started again.
Old 08-16-2017, 01:09 PM   #7
MLue1
Lightbulb
Just went to the Dealer to get CV boot for my car, spoke to a mechanic while I was waiting for the part about your problem, he says you have a gasket leak when warm throwing off the computer, he suggest using a smoke machine to trace it, they hook up the smoke machine to the vacuum hose and let it run. He also suggest checking the PCV for leak.
Old 08-17-2017, 03:00 AM   #8
onecrazyfuq
I thought on these cars the pcv was integrated into the valve cover
Old 08-17-2017, 08:43 AM   #9
MLue1
Lightbulb
Yup !
It could be just the PCV diaphragm in your valve cover tore or it could be the heat cycles have caught up with you and the valve cover gasket is leaking. The round part of the valve cover comes off to reveal the diaphragm.
http://germanoem.ca/parts/air-intake...98pcv-fix.html
