Old 08-09-2017, 10:19 AM   #1
Acoolusername
Acoolusername's Avatar
Drives: Vw GTI mk6
Water pump concerns
So after reading on here a lot it seems to be the water pumps constantly fail. Mine has not yet luckily. I want to be prepared if it does. I'm learning a lot from this forum but I'm a noob with this stuff. I want to know what the signs are. I'm guessing of course the fluid will be low under the hood. I drive an hour to work every day and wondered what would happen if the car overheated on the highway. Do you let it sit for a while before driving again? Is there a certain temp that you don't let it get past on the gauge?
Btw this forum is a gold mine for maintenance and repairs.
Acoolusername is offline   Reply With Quote
Old 08-09-2017, 11:02 AM   #2
ahard48
ahard48's Avatar
Just keep on eye on it, check the reservoir once in a while. Your low coolant light will go on if its leaking below min. Id keep a small bottle of G2 coolant(with distilled water) in the trunk just in case this happens you can top off. If you see leakage contact dealer for replacement.
2014 GTI Wolfsburg:
Old 08-09-2017, 11:36 AM   #3
Acoolusername
Drives: Vw GTI mk6
Thank you for the reply. Is covered under a recall or warranty? Mine is a 2012.
Old 08-09-2017, 01:15 PM   #4
ahard48
ahard48's Avatar
I'm almost positive its all under warranty no matter what year. Mine was 2014 and started leaking and VW covered it all. If you have your VIN handy you can look it up at this site and will tell you:
http://www.vw.com/owners-recalls/
2014 GTI Wolfsburg:
Old 08-09-2017, 01:55 PM   #5
ZiggyMKVI
ZiggyMKVI's Avatar
Drives: 2010 Black GTI
Mine doesn't have any recalls
2010 GTI _ mods: Magnaflow-Catback, DG short shifter, BSH catch can, Neuspeed Throttle body and Discharge Pipe, ESC intake, R8 Coilpacks, Forge Motosports coilovers, Rotiform TMB 18 x 8.5, SPM Catless DP, Stage 2 Unitronic, ARM front mount
IG: Scottziggs
ZiggyMKVI is offline   Reply With Quote
Old 08-09-2017, 04:19 PM   #6
Acoolusername
Drives: Vw GTI mk6
Just looked at that link. Mine doesn't say recall either :/ Either way what happens if your car over heats on the highway. Just poor more coolent/water mixture in ?
Old 08-09-2017, 04:35 PM   #7
ahard48
ahard48's Avatar
Yea I'm sure that's fine. I'd call dealer as well just to double check, I don't know why it doesn't mention water pump recalls...
2014 GTI Wolfsburg:
Old 08-09-2017, 05:28 PM   #8
Acoolusername
Drives: Vw GTI mk6
Okay thanks for the help! Also in your honest opinion what oil do you use in your changes. I thought about starting them myself wth the help of one of the stickies I saw on here. I've been taking my car to a local place for 60 bucks full synthetic. The forum shows that I would be paying more than that doing it myself.
Old 08-10-2017, 08:45 AM   #9
ahard48
ahard48's Avatar
As I was driving to work this morning I had a thought; I wonder if the recalls are not showing up if this is a "new to you" used car? If so the original owner may have had it replaced and therefore no longer a recall item. Still call and double check.
As for oil changes I have the dealer do it. I used to do them myself on my last car (Hyundai) but not for my VW.
2014 GTI Wolfsburg:
Old 08-10-2017, 12:38 PM   #10
aj_law
aj_law's Avatar
Mobil1 0w40. A jug at Walmart with filter/crush washer (from dealer or wherever online) will cost you $35-$40 out of pocket.
Old 08-10-2017, 12:47 PM   #11
Acoolusername
Drives: Vw GTI mk6
Hey thanks. I guess I'll go that route and do them myself then. That way I know what's being put in. I see in your sig you hit 100k miles. That's good news because I put a lot of miles on my car and I just got it. Im about to do the dreaded dsg oil change myself. Did you do yours every 40k?
Old 08-22-2017, 07:19 AM   #12
nvturbo
nvturbo's Avatar
WRONG. It is only covered if the VIN is on their list, which is obviously the size of a Post-it note pad.
OP, do yourself a favor and replace it yourself because I wouldn't trust those idiots at VW to do the work. It will leak again within 5K miles if they do.
....used to own a MK6 GTI
Old 08-23-2017, 11:08 AM   #13
aj_law
aj_law's Avatar
Mine is a MT, not DSG.
I'll say that if I did have a DSG, I'd probably err on the side of caution and do it more frequently. I'm also firmly in the oil change every 5K mile camp too.
Old 11-09-2017, 04:02 AM   #14
kerp
kerp's Avatar
Drives: 2012 GTI CW
Water pump concerns
My '12 (CCTA) pumped failed a couple weeks ago. In the middle of classes so really had no time to DIY, unfortunately. Dropped it at mechanic, who has serviced my family's cars for decades. Not concerned about him trying to rip me off, I didn't get a quote until I had already dropped the car off.
I got a phone call around 1:30, after dropping the car off at 8:15. My jaw dropped when he told me. I called back 20 minutes later wanting to cancel the work, but the owner said they already started. He assured me they would do a good job and he it really put me in an uncomfortable position.
All in all, I was charged $692.20 in labor and $432.39 in parts for a grand total of $1,124.59. On top of that, my tuner quoted $653 out the door for the same job.
In addition, $82.60 for a fuel filter swap (I even provided the filter...) Yes, I know that's an easy one but figured it couldn't be too much since they were already under there. To top it off, they scratched my mint RSe12's in a few of the lug holes (had my brakes flushed too but didn't factor that into the numbers I posted).
I'm pretty bummed out, wanted to drop the car and not worry but this really ruined my weekend. Does this not sound a bit excessive to you guys?
kerp is offline   Reply With Quote
