Old 05-31-2017, 11:19 PM   #1
JISUN_GTI
Drives: 13 GTI wolfsburg edition
Replacement Horn? Warranty?
i have 2013 GTI with 39K Mile and sec owner . and my horn does not work.
if i press no sound other than clicking.
will this cover by warranty if i have one?
2013 GTI MK6 Wolfsburg - Stratified Tune - Carbon Fiber Intake System with Rear Inlet Pipe - APR DOWNPIPE - APR INTERCOOLER - BORLA CATBACK EXHAUST - APR DSG Tune
JISUN_GTI is offline   Reply With Quote
Old 06-01-2017, 07:33 AM   #2
Blakcard
FIA GT Newbie
Blakcard's Avatar
Did u check fuses?
by the time you've read this, I'd have already done.....this > Mostly stock, APR stage 1 2.4 file, Stoptech rotors, GTS G707 rims, GFB DV
Old 06-01-2017, 09:22 AM   #3
damagi123
damagi123's Avatar
Drives: 2012 GTI DSG
this has happened 2 different times on mine in 70k miles. its not likely its fuses, the dealer told me it was the clock spring
Old 11-10-2017, 09:18 PM   #4
Syze00
Drives: 2012 GTI
I've had multiple horns go out on my GTI. Its a quick job and it was covered under warranty for me. There is actually two horns but the one that goes bad is the one that honks when the button is pressed. I suggest everyone test their horns out periodically because that's a very small thing that can mean the difference between someone crashing into you or not.
Syze00 is offline   Reply With Quote
