Old 08-12-2017, 12:46 PM   #1
mjstlwell
Drives: 2010 Golf TDi Sportwagen
Gravel in my transmission?
In 4th and 6th I now get a definite loose gravel sound from my transmission; dead quiet in the other gears.
There do not seem to be drivability issues and fuel economy has been as low as 4.3l/100km.
Acceleration is as expected and the noise is less in 6th and diminishes with the load.
Suggestions?
Already ruled out clutch and flywheel since the sound is definitely from the transmission.
mjstlwell is offline   Reply With Quote
Old 08-12-2017, 03:22 PM   #2
FocalPoint
FocalPoint's Avatar
Drives: MKV GTI/MKVI GTI
Sounds like it could be synchros.
Old 08-12-2017, 09:36 PM   #3
MLue1
Lightbulb
Suggestions?
First things first, have you checked the fluid levels, 5th and 6th are physical smaller gears so they may not be getting oiled if the level is low and there are no pumps inside a manual transmission, so lubrication is a matter of the oil being thrown around which also decreases when the level is low.
You could have a bearing that support these gears going bad, which would explain less noise under load.
