Old 09-25-2017, 04:03 PM   #15
Dabbsy
Drives: Golf 1.4 TSI
Originally Posted by Carlosfandango View Post
I would check the in tank fuel pump next, Check the fuel pump in the tank by lifting the rear seat base, it could well be faulty, also the electronic part located in the black pump cover can overheat and cause problems, ( you can diagnose this by feeling if itís hot ),
This video should be of help,
https://youtu.be/5hTNWo3E4nE
Thanks again for your advice, I am popping the car into my local VW specialist tomorrow. They will run a diagnostics check on the car, and I will show the video I took too. Hopefully its something simple and not something costly.
Dabbsy is offline   Reply With Quote
Old 09-28-2017, 10:49 AM   #16
Carlosfandango
Carlosfandango's Avatar
Drives: 2010 MK6 GTI 6MT CSG
Any luck finding the issue??
Fuel filter wonít put out a code, you just get symptoms! Pretty sure the same applies to the pump but not 100% sure on that!
Old 09-28-2017, 11:20 AM   #17
Dabbsy
Fuel filter won’t put out a code, you just get symptoms! Pretty sure the same applies to the pump but not 100% sure on that!
The garage could not find anything, I have not checked the fuel pump yet but will do when I get a moment.
Old 11-12-2017, 12:51 PM   #18
Dabbsy
Just thought I'd update my status. So I have changed the fuel filter twice, had the ignition switch replaced and still I am getting this starting problem. It is happening more often now, is there anything which I may have overlooked?
Old 11-12-2017, 12:56 PM   #19
Carlosfandango
Fuel pump!
Old 11-12-2017, 12:58 PM   #20
Carlosfandango
When did you last change your spark plugs? I also had plugs fitted at the same time as the filter so they may have played a part in solving it!
Old 11-12-2017, 01:01 PM   #21
Dabbsy
Hello again Carlos. I changed the spark plugs around 3 months ago. Sorry you mentioned the fuel pump, i have not looked at that as unsure what to do?
Old 11-12-2017, 01:53 PM   #22
Carlosfandango
The video I posted earlier in the thread explains all about the pump.
Old 11-12-2017, 03:26 PM   #23
Dabbsy
Thanks for your help I did see that originally, I hear the fuel pump go off when I turn the key once so I was not sure if it was an issue. Would I need to have the car on for sometime for me to see if its overheating?
Old 11-12-2017, 03:54 PM   #24
Carlosfandango
Iím not sure to be honest! As I fortunately didnít have to go that route, But any mechanic worth their salt should be able to troubleshoot the things that might cause the issue, my guess would be itís fuel related though.
Old 11-12-2017, 04:03 PM   #25
Carlosfandango
I think youíve used the wrong filter if the bar pressure was 6.4 originally that is what you should be using, not 6.6!
Old 11-12-2017, 05:17 PM   #26
Dabbsy
I think you’ve used the wrong filter if the bar pressure was 6.4 originally that is what you should be using, not 6.6!
When searching for a new one i was directed to a thread which mentioned that the 6.6 bar filter had superseeded the 6.4 one, maybe all this time it was the 2 filters I got at 6.6 bar which is where the issue lies? All searches to a another filter point me to a 6.6 bar filter including eurocarparts, maybe it is correct?
Old 11-12-2017, 05:30 PM   #27
Carlosfandango
When searching for a new one i was directed to a thread which mentioned that the 6.6 bar filter had superseeded the 6.4 one, maybe all this time it was the 2 filters I got at 6.6 bar which is where the issue lies? Worth a shot ill get a 6.4 one, if this still is the issue ill look at the fuel pump as you mentioned
As long as the original was 6.4 then give it a go, It could be that 6.6 is now correct but Iím under the impression that bar rating is the opening pressure and that would suggest it would be more difficult for your fuel pump to push fuel through the filter if it should operate at 6.4bar, once running the high pressure fuel pump would mask the low pressure tank pumps struggle, there is also a 4.0bar filter available so make sure you get a filter matched to your VIN, preferably get it at the dealership or TPS, i was told by Jamie at TurnerRaceDevelopments that it has been known for the wrong filters to be put in the wrong boxes so check the pressure stamped on the filter its self, what was the bar rating on the originally replaced filter??
Old 11-12-2017, 05:59 PM   #28
Dabbsy
It was 6.4 bar on the original filter i changed when I got the car to a 6.6 bar one.
