Old 09-09-2017, 04:53 PM   #1
macrossplus
Drives: 2010 GTI DSG
MK6 GTI CBFA motor replaced with NEW CCTA motor?
Straightforward question, but probably a difficult answer:
MK6 GTI from california (has CBFA). Want to install a new, complete, identical motor, but it is a CCTA, so 2 cats instead of 3.
I have all working parts in the car... in other words, it isnt a wrecked car, had no problems before....just grenaded the motor BC of the faulty belt tensioner.
The new engine is complete with turbo and piping.
the question is WIL THE CAR RUN (I am TOLD that it will run, no problems, but will throw an engine code that I can reflash at a later time).
Does anyone know whether this can be done without crazy shit done to the car?
macrossplus is offline   Reply With Quote
Old 09-12-2017, 11:10 AM   #2
sauceman101
sauceman101's Avatar
Drives: 2010 UG GTI 6MT
At the very least, the SAI system will need to go. The water pumps are different as well. IDK if the turbo's are identical, I'd imagine so, not sure which location of the 3, for the 02 sensors goes.
Can't answer if the car will run, but those other bits you will need to deal with. IF it does run, I imagine you'll be throwing more than just one code. Not sure if the ignition system that is paired to your ECU has some way of identifying a "different" motor, not the CCTA CBFA thing but a different motor that it is paired too. I know these ECU's are relatively complex compared to say a ford or chevy.
2010 UG GTI 6MT: Peloquin LSD, APR Stage 1, DIY RSR Clutch, VWR Streetsport+ Coils, IE Camber Plates, 034M Front End Links, Hotchkis RSB, APR Stage 1+2 Carbino Intake, HPA Red Subframe Puck, Enkei PF01s wrapped w/ Star Spec 2s, AWE DP, [i] Magnaflow CBE, BIG things coming if you catch the drift
sauceman101 is offline   Reply With Quote
