Old 09-20-2017, 06:07 AM   #1
jordy6
jordy6's Avatar
Drives: Vw golf mk6 1.6 TDI
2012 1.6 TDI 5 speed manual shaking
Today and it happened before too my car started shaking while in 3rd or 4th gear at about 1200 rpm no accelerating just cruising. Before I take it to the garage because it's still under warranty I would like to know what the problem could be.
Also it goes in reverse very rough often with a bit of grinding too.
Verstuurd vanaf mijn HUAWEI CRR-L09 met Tapatalk
Old 09-26-2017, 12:33 PM   #2
jordy6
jordy6's Avatar
*Update* i found the problem, the clutch doesn't disengage properly, that explains the rough reverse shift and that the clutch pedal is heavier. It probably also causes the shaking
