Old 09-21-2017, 09:59 AM   #1
Ik1015
Drives: mk5 ug
CTS Motor Mount
Anyone has CTS motor mount? I can't find any review.
What is different b/w 034 street density motor mount and CTS motor mount?
Ik1015 is offline   Reply With Quote
Old 09-21-2017, 11:16 AM   #2
BlueE30
BlueE30's Avatar
Drives: 10' TR GTI 6M and an E30 325 Turbo
Didn't know CTS had one thought they used or sold BFI
2010 TR GTI APR Stage 1 Fully Loaded, APR Carbonio, R8 coils, Rotiform 19's, Koni Coilovers, CTS subframe reinforcement kit, CTS Billet Torque Arm Insert, CTS rear subframe bushing kit, LED Golf R Tail Lights, Xenon Headlights, VCDS changes (DRL's, windows, gauge sweep, etc) and timing chain tensioner updated!
1987 BMW E30 325 Turbo - Too extensive to list.
BlueE30 is offline   Reply With Quote
Old 09-21-2017, 11:38 AM   #3
Ik1015
Drives: mk5 ug
Maybe same as 034 or copied from them.....bit cheaper than 034, but no review at all....
Old 09-21-2017, 11:51 AM   #4
Tony48
Tony48's Avatar
Looks like a direct copy of 034 mounts. Same specs as 034 Streetline: 60 durometer void-less rubber. In for more info.
Old 09-21-2017, 01:53 PM   #5
lilonespaz
lilonespaz's Avatar
they are the same price as 034 just right now CTS is having a sale which makes them about $20 cheaper than 034.
Ill still probably end up getting 034 as it is not a big enough price incentive to move me away from the well known brand mounts that is 034.
Old 09-22-2017, 12:12 AM   #6
Short Bus
Drives: '10 GTI
I've had the 034 mounts for a while now. They're good. I'm sure the CTS mounts are good too. I'm very thankful that we have aftermarket options that use rubber.
Old 09-22-2017, 07:49 AM   #7
GreyGti1990
Drives: 2011 Gti 4-door
Yup those look exactly like the 034 mounts.
Old 09-22-2017, 09:10 AM   #8
Jaber
Modero
Jaber's Avatar
What's the price of CTS? USP had the cheapest price on 034 SD mounts, when I bought them. The new bolts are kind of expensive
Member Journal
Old 09-22-2017, 09:52 AM   #9
lilonespaz
lilonespaz's Avatar
Modded euros has them right now for $101.99 a piece on sale(CTS has a sale) otherwise they are normally 119.99 (x2 is $240 which is same price as the 034 motorsports kit regularly). USP has the 034 kit for sale for $211 right now. No bolts though.
Modded euros offers the replacement stretch bolts as a add on to the mounts at the price of $16 for the engine bolts and $28 for the transmission bolts.
That seems like a good price for the replacement bolts.. as ECS charges like $80 for the kit of bolts.
So right now you can buy both mounts with the bolts for 247.98 from Modded Euros due to the sale.
Old 09-22-2017, 10:09 AM   #10
Jaber
Modero
Jaber's Avatar
Not a bad price. Wonder if those bolts are OEM, from ModdedEuros. I made the mistake of buying from dealer, was $10 more than ECS.
$247.98 vs ~$271 for 034, could be worth it, if the quality is the same.
Member Journal
Old 09-22-2017, 10:14 AM   #11
lilonespaz
lilonespaz's Avatar
looks like they are the description of the add on is "Optional Replacement Strech bolt" but if you hover over the little ? mark symbol it says "Optional replacement OEM stretch bolts: for CTS Turbo Mounts"
Old 09-26-2017, 09:37 AM   #12
lleron
Drives: 2012 2dr 6spd White GTI
I have them and am pretty happy. I also bought the stretch bolts which were actually slightly different (and slightly shorter for the motor mount bolts) but have been fine since install.
I have nothing to compare them to unfortunately. The NVH increase is trivial, I initially had a BFI transmission mount insert in before replacing the full mount with the CTS one and it was much worse.
lleron is offline   Reply With Quote
