Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Marketplace > Private Classifieds - Buy, Sell and Trade
Old 11-02-2017, 03:57 AM   #15
MmmmmBoost
Drives: 2013 GTI MK6
Are you able to source cheaper Boxster Calipers brackets to swap onto the mk6 ?
MmmmmBoost is offline   Reply With Quote
Old 11-02-2017, 10:08 PM   #16
rawag77
Drives: 2013 GTI Autobahn
+1
rawag77 is offline   Reply With Quote
Old 11-08-2017, 11:37 PM   #17
joshterrell861
joshterrell861's Avatar
Whats that have to do with what hes selling. And yes creationmotorsports in the uk sells cheaper brackets. I just ordered 3 sets. 2 for boxster and 1 for 911 caliper swap
Sent from my SM-N920P using Tapatalk
joshterrell861 is online now   Reply With Quote
Old 11-08-2017, 11:45 PM   #18
BringerOdeath
BringerOdeath's Avatar
Drives: 2011 GTI Candy White
Originally Posted by Rylopes5 View Post
Whats the difference between the 17z and 18z? and what is required to make these bad boys fit?
The 17Z uses a 330mm rotor and the 18Z uses 350mm rotor.
Originally Posted by Mbutler183 View Post
Interested in the Brembo 17z setup
I can definitely get you 17z calipers if you would like them.
That I cannot, you either have to get the apikol, creation motorsports, or VAGBREMTECH brackets.
K04 G.I.A.C. Tuned, Godspeed FMIC V2.0, R8 red Coilpacks, Volant Intake, Fastbits DV+,42 Draft designs DP-high flow cat, Fluidampr, 034 motorsports street engine/tranny mounts, Vibratech Subframe insert, 034 motosports aspherical dogbone, 034 stainless subframe collar kit, IE Africa plate, AWE S3 style Charge /discharge pipes, Koni Coilovers, TSW Donington wheels, Golf R side skirts, TTRS BBK, Dual caliper Cayenne rear BBK
Old 11-20-2017, 06:27 PM   #19
-SnowmanMafia-
Drives: 2013 Golf R
Do you still have the RS calipers for 360?
Also, I know they take the 370mm rotors. Are those direct bolt on without hub adapters or anything?
Everyone seems to go OEM and spend 200/rotor but these Stop Techs would work, no?
CENTRIC 12633121SR StopTech Sport Slotted
CENTRIC 12633121SL StopTech Sport Slotted
They're listed on multiple sites to fit the RS front rotors and are labeled as 370mm
https://centricparts.centriccatalog....&uid=ANR&sid=0
Edit: Nevermind... those are the rear rotors after finding a diagram showing the size.
Custom 3in Catback | Unitronic Stage 1 | Neuspeed P-Flo Intake | Smoked Bumper Lights | OEM Euro Tails
-SnowmanMafia- is offline   Reply With Quote
Old 11-22-2017, 10:52 AM   #20
BringerOdeath
Sorry for the late delay, but yes, I should be able to get you a set for $360.
Yeah, I don't think even stoptech makes an aftermarket 370mm front rotor. I think someone makes a 2 piece, but I just went for the OEM K revision rotors on mine. I think EEuroparts has the sheapest price and they have coupons that bring each rotor under $200.
Old 11-22-2017, 04:31 PM   #21
BringerOdeath
All the ttrs parts are direct bolt on. No hub adapter as both cars have the same size hub.
Old 12-02-2017, 12:28 AM   #22
webbry4
webbry4's Avatar
Able to get a hold of boxster calipers?
Old 02-23-2018, 04:09 PM   #23
alex654
Drives: mk6 golf tdi
What would I need to run the ttrs on a r
Sent from my SM-G955U using Tapatalk
alex654 is offline   Reply With Quote
Old 02-23-2018, 04:30 PM   #24
BringerOdeath
You need either the stock TTRS 370mm rotors or you can use these caliper carriers to use the stock golf R 340 or 345mm rotors:
https://www.vagbremtechnic.com/front...-discs-ak0003/
This kit comes with the braided steel lines you would need as well. That's all you need! It's prettty much a direct bolt on with the oem rotors from audi or the caliper carriers from vagbremtech. The oem rotors are something like 220 a piece, so the new carriers would be the cheaper solution if you go with the stock R rotors.
You also need to buy brake pads of course!
Old 02-23-2018, 05:10 PM   #25
DASVDUB
DASVDUB's Avatar
in4futurebrakes
