Old 09-23-2017, 09:37 PM   #1
dcpppf
dcpppf's Avatar
Drives: 2012 VW GTI Autobahn
New fuel filter and spark plugs = lower MPGs?
I replaced my fuel filter and spark plugs a few weeks back and have noticed quite the drop in fuel mileage. ~ 40-50 miles per tank.
I believe the new fuel filter went from 6.4 bar to 6.6 and my new plugs were .028" gapped (APR stage 2 recommendation).
Any reason why such a drastic change in fuel mileage??
2012 CSG GTI MT Autobahn Timeline: 20% Tint // Clear Bra // APR Stage 1 Tune // DG Short Shifter // Verdict Shifter Bushings // 10" Uberstealth Sub Setup // Soundaktor Delete // BFI Dogbone Insert // APR 3" Downpipe & Tune // ECS Auto Hatch Pop // DEPO Black Cherry Tails // R8 Packs // Tinted Side Markers // Sachs SRE Clutch + PP // DV+ // Shortened Shifter Shaft // deAutokey LEDs // Polar FIS Adv// Euro Headlight Switch // Dash Cubby // Unitronic CAI (replaced Carbonio) // Unitronic Catback
dcpppf is offline   Reply With Quote
Old 09-23-2017, 09:50 PM   #2
MLue1
You need to reset the long and short term fuel trim by reseting the ECU, as the car is still compensating for worn parts.
Old 09-25-2017, 07:40 AM   #3
dcpppf
dcpppf's Avatar
Hmm, noted. I'll disconnect the battery for a bit tonight when I get home.
Any way to reset the fuel trims with VCDS? Sounds like just clearing fault codes will, but not sure.
Old 09-25-2017, 06:24 PM   #4
MLue1
Yup
Old 09-25-2017, 09:13 PM   #5
11gti718
you probably did it already but clearing VCDS will reset LTFT AND STFT.
Old 09-26-2017, 07:49 AM   #6
dcpppf
dcpppf's Avatar
Didn't seem to have much of an effect on this mornings commute. But will give it a tank or two before trying something else! thanks for the help everyone.
