Old 09-27-2017, 05:36 PM   #1
adema69
Drives: mk6 gti
CALLING APR KO4 TURBO PEOPLE
Hello guys I have a question for the APR ko4 users. Do you know if apr adjust the waste-gate actuators to 22psi max output? I have the cobb accessport and cant get the car to boost more than 22-23psi even when its requesting 29psi?
Any insight would be greatly appreciated..
I am currently trying to see what I can achieve hp wise on the ko4 with e40 and methanol but limited with the psi.
adema69 is offline   Reply With Quote
Old 09-27-2017, 05:41 PM   #2
jay745
jay745's Avatar
No they don't. I have an apr k04 on my car with their 3.1 tune. It hits 29 all day.
Old 09-27-2017, 05:50 PM   #3
adema69
Drives: mk6 gti
thank you!
Old 09-27-2017, 06:27 PM   #4
APRMK6GTi
APRMK6GTi's Avatar
Its because of the 3 bar map sensor that APR utilizes. I dont believe any other tuners use it.
Nor Cal VW Drivers Club
Old 09-27-2017, 07:11 PM   #5
FriggenT
What's your wgdc out of curiousity?
Old 09-27-2017, 09:36 PM   #6
Grant@COBB Tuning
Drives: '13 | GTI 2DR | 6spd | Candy White
We have support for the 3 bar map sensor through AccessTuner Pro. It was part of our last update for VLK-001.
Grant@COBB Tuning is offline   Reply With Quote
Old 09-27-2017, 11:04 PM   #7
FriggenT
I was told by UM that the 3 bar didn't matter and it would still get above max stock map sensor. Also driver motorsport didn't need one either, as it would peak 25 psi on most setups.
Old 09-27-2017, 11:46 PM   #8
Chris659
Drives: 12 Beetle Turbo
Edit
Old 09-29-2017, 10:20 AM   #9
damagi123
damagi123's Avatar
Drives: 2012 GTI DSG
Im in the same boat. may be a leak unless you have a huge IC then its probably just a byproduct of more volume
Old 09-29-2017, 02:30 PM   #10
vwgti2.0t
Drives: 2011 CW GTI
I think it's a Cobb related issue. On the APR file my car, and every other V3.1 car hit 27-28psi every time back when it came out. And they don't touch the wastegate.
This is the second time I've heard of someone running Cobb that can't request about 22psi even with the new map sensor, and the other person I know is on a big turbo.
Old 09-29-2017, 03:03 PM   #11
Injen1us
Injen1us's Avatar
Drives: MK6 gti
Its your tune/tuner. The turbo and 3bar map sensor will hit 27-28 all day.
Been APR V3.1 tuned for 45k miles
2800lb k04'd daily driver
Radical Edward
Old 09-29-2017, 05:11 PM   #12
Jcarollo765
What they said 27-29 easyyyyy. Love looking at my boost gauge
Night Fury '13 Wolfsburg GTI/Carbon Grey/4-Door/DSG
Current Mods: APR K04 V3.2 & TCU V1.6//42DD DP//Unitronic Intake//H&R 26/24 Sways//Unibrace XB//SuperPro ALK//BSH Engine & Pendulum Mount//HPA 75a//Do88 Intercooler//H&R Cup Kit//Evo Boost Gauge//Soumatrix Speakers//BFI Stage 2 Tran Mount//GFB DV+//H&R 10/10 Spacers//Tyrol Brake Kit & Pads//Corgi Hair
Jcarollo765 is offline   Reply With Quote
Old 09-30-2017, 10:46 AM   #13
FriggenT
Not with my intercooler it wouldn't
Old 09-30-2017, 02:55 PM   #14
brobst
brobst's Avatar
Drives: CSG mk6 6MT
I was going to say, the IC and location should affect it. Plus if you have the pipings and such. Less volume, more pressure. Move more air, lower psi for same power.
