Old 09-28-2017, 01:33 AM   #1
henryjye
S3 IC + FMIC or is it too much
I m running a k04 with S3 IC currently , been thinking should i add a FMIC to reduce the chances of heatsoak but am afraid it might cause some lag ?
Did someone run similar setup ?
Pros and cons ?
The temp here is always around 33c btw.
henryjye is offline   Reply With Quote
Old 09-28-2017, 02:01 AM   #2
11gti718
i was running a slightly different setup. Had a golf r intercooler + forge twintercooler. Didnt really like it. Temperatures were abit high still and heat soak sucked big time sine now its 2 IC being heat soaked. Switched up to Armed fmic and no complaints as of now. temps are lower for sure
Old 09-28-2017, 07:05 AM   #3
nvturbo
nvturbo's Avatar
get a custom FMIC and you won't have to worry about lag.
....used to own a MK6 GTI
Old 09-28-2017, 09:24 AM   #4
FriggenT
I just got a big ass smic and hardly go over ambient temps
Old 09-28-2017, 11:04 AM   #5
11gti718
which IC exactly if you dont me asking.
Old 09-28-2017, 11:58 AM   #6
henryjye
mind if i ask what brand is it
Sent from my MHA-L29 using Tapatalk
Old 09-28-2017, 12:25 PM   #7
FriggenT
Wagner...1057 ci volume
BUT! If I already had the s3, I would look simply into a WMI setup even if just for cooling. Only way you'll ever get below ambient temps.
Old 10-02-2017, 12:25 AM   #8
henryjye
thanks for the info bro
appreciate it
