Old 09-29-2017, 04:08 PM   #1
ctvw14
Drives: 2012 Golf 2.5
Car won't start with new coil packs?
Already posted this in the 2.5l specific section but turned up few results so I figured I'd repost it here...
Car is a 2012 Golf 2.5l. Going back to last year, the car developed a misfire across all cylinders and eventually died on the highway. Engine would crank but not start. New coil packs were installed and problem was solved.
A few months ago, car developed a very similar misfire. (Slight misfires noticed at idle, heavy stumbling under medium/heavy acceleration, between 2500-4500rpm.) I installed another new set of coil packs and the engine will crank all day long but won't start. Crank position sensor was replaced, spark plugs were replaced, even tried two other sets of coil packs and nothing will work. The strangest part is that when I reinstall the old burned up coil packs, the car will start up just fine, it will just continue running with the random misfire. At this point I know it's just a matter of time before the coil packs actually fail and I'm left on the side of the highway again. I know the new coils shouldn't be the problem because I've tried them in two other 2.5l's and both cars started up just fine.
I've talked to a number of VW service centers, fellow enthusiasts, and even put a call in to VW America and NOBODY has an answer. If anyone has any idea why the car will run will the old coil packs but won't start with brand new OEM coils it would be appreciated. Thanks.
ctvw14 is offline   Reply With Quote
Old 09-29-2017, 04:14 PM   #2
jay745
jay745's Avatar
the r8 coil packs that people use on gti's work great on 2.5's as well. If your OLD coil packs work, then the new ones are definitely faulty.
Old 09-29-2017, 04:19 PM   #3
ctvw14
One of the new sets I tried were OEM red tops from ECS. The other set were OEM black tops directly from VW. Both work fine when installed on my buddy's 2.5l, but the minute I put them in my car it will crank but won't start.
Old 09-29-2017, 05:13 PM   #4
m3dv3d
Drives: MK6 GTI 2010
Wild guess, the electrical connectors to the coil packs have become unique to the old coil packs. See if anything looks bent or out of place. It may be as simple as a crappy connection.
m3dv3d is offline   Reply With Quote
Old 10-03-2017, 04:34 PM   #5
ctvw14
Quick update on the issue...I test fitted 5 new coil packs this morning (the cheap Denso ones from Advance Auto that were previously in the car) and the car fired right up first try...Got home and put in the R8 red tops and they still won't fire...is it possible that the ECU adapted to the cheap coil packs and now will only run with that specific type?
I've never heard of a car adapting so much to a specific component like that, but now I'm wondering if a complete ECU reset will fix the problem. I tried touching the +/- terminals together to reset it that way but it didn't change anything. Maybe a full adaptation reset with VAGCOM?
Old 10-06-2017, 10:33 PM   #6
uglybastard
uglybastard's Avatar
doubtful. faulty parts are extremely likely here.
..246.............. Insta
Old 10-07-2017, 07:32 PM   #7
nvturbo
nvturbo's Avatar
OEM red tops doesn't mean they're actual R8 coil packs. This has been discussed before in other threads.
Old 10-08-2017, 06:16 PM   #8
Sauce118
Sauce118's Avatar
ECS sells "red top" coil packs that are not R8's. When upgrading, make sure you actually buy R8 coil packs instead of just the red tops. FYI
**update... didn't see the post before mine.. sorry***
2010 GTi 6mt: Candy White: CTS K04 W/APR v3.12: AQUAMIST HFS-4 v3.1 W/M Direct Port: Peloquin LSD: Wilwood BBK: CTS Downpipe: Beluga CatBack: ARM Motorsports FMIC: CTS CAI: CTS BOV Kit: RSR Clutch: CTS Charge Pipes: Fluidampr Pulley: Koni Coilovers: WALK Kit: SPM Full Mounts: DieselGeek SS w/ bushings: Eurosport Front & Rear Strut Bar: STERN Brace: HID's: 'R' Grill: Various Cosmetics GT3073R BUILD IN PROGRESS!!!
Old 10-09-2017, 04:31 PM   #9
ctvw14
Didn't realize the red tops from ECS were different from actual R8 coils but that's good to know for future reference. As far as the parts being faulty, I just find it strange that 3 separate sets of coil packs, (one set from ECS, two sets of OEM coil packs direct from VW) would all be faulty...especially when they work perfectly fine when installed on a different car...it was only when they were installed on my car that they wouldn't fire.
Old 10-09-2017, 04:49 PM   #10
Blakcard
Blakcard's Avatar
I think you already solved the issue. If they are working on other cars... but not yours, and your old ones work... that has to be the issue you need to resolve. It's usually a straight swap however as you're experiencing results outside the normal I would start there. Might not be the coil packs
Old 10-09-2017, 08:52 PM   #11
uglybastard
can always look to replace the harness that connects to the coils.
