Old 10-02-2017, 03:19 PM   #1
WalkerT
WalkerT's Avatar
BFI DSG shift knob review
My review
Product: Black Forest Industries BFI GS2DG Shift knob -Alcantara shift boot
Price: $179 for the knob and $79 for the boot
Part number: GS2DG (heavy with air leather) Boot 5234-1k-232
I was sick of the OEM plastic Crap knob and vinyl shift boot
Includes:
One GS2 shift knob
One BFI crest logo coin
One DSG / S-Tronic / Tiptronic / Automatic shift adapter
Four set screws
Allen key for set screws
Install:
This does take a patient hand. The removal of my shift knob was not the easiest. Mine was the pull up style and it gave one hell of a fight. Once off the install of the Boot was straight forward. See pics. BFI has invented a dual barrel mechanism that replaces the button on the front of the DSG knob. Installing this will take several adjustments to find the sweet spot. It will need to slide up and back down without resistance. There are four hex screws that, once in the right location, will work perfect. As you can see in the one pic, the first couple tries the shifter would not sit flush with the collar of the DSG. Got that fixed. Once installed you just lift up to disengage the shifter and select the mode.
Driving:
I love this! You touch two things in a car while driving, the steering wheel and shifter. When you upgrade the shifter it takes the tactile driving experience to a higher level. I would never use the oem shifter to up/down shift because it felt like crap. This totally changes that, and it really is R8 quality.
http://www.blackforestindustries.com
MK6 VW Driver's Group@Facebook 2012 GTI DSG Unitronics stg2, Billy boat 3" DP, IE intake, CTS 3" catback, D088 Intercooler, BFI stg1 engine mounts, O.Z. 18x8 Alleggerita, Charge pipe, up pipe, NS vent boost gauge, BFI DSG shifter, H&R sport, H&R adjustable rear sway 26mm, Koni orange, R8 coils
WalkerT is offline   Reply With Quote
Old 10-02-2017, 07:50 PM   #2
notovicrious
notovicrious's Avatar
Drives: 2011 GTi 2.0T
I also love the knob but mine recently started to shift and now the screws are loose, I never used loc-tite though so Iím going to have to try that next. Other wise the knob is very very cool. Just my 2 pennies.
Old 10-02-2017, 08:53 PM   #3
WalkerT
WalkerT's Avatar
Yeah I used the loc-tite on mine and hope that will prevent it. I will update as I use mine.
Old 10-02-2017, 09:25 PM   #4
Trytun
Trytun's Avatar
Drives: 13 CSG
Careful with that knob. Over the course of daily driving for awhile, the screw inside sheared off the top of the plastic loop.
Here, the broken off piece of plastic is barely visible inside the knob.
It cost me quite a lot to get the entire shift assembly replaced and the center console removed. BFI never even responded to me.
I loved that knob but the cost was extreme.
Unitronic Stage 2/Unitronic Stage 1 DSG Tune/APR Downpipe/Neuspeed Catback/Miro Shit Wheels/30% all around/Solo Werks S1 Coilovers/TTRS Strut Mounts/Unitronic Intake/Unitronic Intercooler/Soundaktor Delete/GFB DV+/R8 Coils/Spulen Discharge Pipe/Spulen Turbo Muffler Delete/034 Motorsports Billet Insert/034 Motorsports Street Density Motor and Trans Mounts/ECS Tuning Rear Sway Bar THE BUILD THREAD
Trytun is offline   Reply With Quote
Old 10-02-2017, 09:31 PM   #5
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
The boot looks good. It looks like all you get is a piece of cloth, so was it a pain to get it installed into the base? I have a manual though, so I'm not sure what the difference would be.
Old 10-02-2017, 09:32 PM   #6
WalkerT
WalkerT's Avatar
Thanks, and I will take it apart after a few weeks to check for stress.
How long had you used it before it broke? Was the actuation smooth?
Old 10-02-2017, 09:36 PM   #7
WalkerT
WalkerT's Avatar
The boot is not a bad install. You get the flat zip tie, and adhesive with the boot. There is a ring that the boot attaches too as seen in the pics above. Once lined up and smoothed out it is just a matter of reinstalling the ring. It is actually a couple mm thicker than the oem vinyl. They also have Leather shift boots, not just Alcantara
Old 10-03-2017, 12:03 PM   #8
notovicrious
I noticed once mine became loose the first time that after I went in and took it apart to analyze what happened that the screw did wear away at the plastic stem. I wonder now, how long will this stay intact. Damn.
Old 10-03-2017, 09:50 PM   #9
Trytun
Trytun's Avatar
Drives: 13 CSG
The actuation was smooth for about 4-5 months. Then the knob was always coming loose. Iíd tighten it and itíd feel better but itíd be loose again in a few days. Then one day I got to work, put my car in reverse and the whole knob came apart in my hand. I had to change gears with a set of pliers for a month while I saved for a new shift assembly and the labor to get it in. Just keep an eye on it - thatís all I can say. It looks sexy and itís nice, I just wish it worked without the drawbacks.
Old 10-04-2017, 09:12 PM   #10
WalkerT
WalkerT's Avatar
Well, I drive the heck out of mine (couple 100 miles a week) so I will check and see if it starts to wear the plastic eyelet. I might just put a dab of lithium grease on it to prevent the friction and wear on the plastic.
Old 10-05-2017, 08:35 PM   #11
notovicrious
Mine didnít bottom out on the top, the screw threaded into the center of the loop. I hope it doesnít rip up and break but I have to check it out again and put loc tite, hopefully it stays and doesnít break. Iím just super gentle with it now.
Old 10-05-2017, 08:51 PM   #12
WalkerT
WalkerT's Avatar
I have a 100+ miles on mine and I removed the knob today and the screw on mine is dead center and does not move at all. I decided against adding any grease, because I dont think I want it to move. As long as it stays centered it should not stress the loop.
Old 10-05-2017, 09:03 PM   #13
notovicrious
BFI shift knob review
I can see it adding stress if the retaining screws become loose like mine have twice which in turn allows you to pull up on the knob and shaft. Until I fix the screws again I pull up on the shaft where it meets the boot under the knob just in case which now that I think of it Iím still pulling up directly on the plastic shaft. No bueno.
Old 10-05-2017, 11:30 PM   #14
WalkerT
WalkerT's Avatar
I added this to the 2.0 engine thread, because it does involve the transmission. Letting you know so if you guys want to added your experiences over there you can.
