Old 10-03-2017, 10:55 PM   #1
jrm_gti
Drives: 2009 GTI
Misfiring Only When Hot & at Idle
09 Tsi Gti, 118k. Car starts up and runs fine for a while, but like clockwork when nearing 40 minutes of driving and coming to a stop or fully stopped, I get a flashing CEL. RPMs drop a bit then go back up as well, Obdeleven shows misfire all cylinders and always misfire on cylinder 1&4.
Its weird, as long as my commute is under 40 minutes, I get no misfiring at all. Car runs great under any kind of throttle. Replaced spark plugs and pcv. I do plan on replacing coils and have a valve cleaning done.
Any help, or insight is appreciated.
jrm_gti is offline   Reply With Quote
Old 10-04-2017, 01:32 AM   #2
Carlosfandango
Carlosfandango's Avatar
Drives: 2010 MK6 GTI 6MT CSG
I wouldnít focus on the 40 minute part! Try moving the coils around and see if the consistent 1 and 4 move to 2 and 3, you should in this situation change the coils especially if the consistent fault moves when you swap them around but Iíd say itís most likely carbon build up though or possibly injectors but less likely.
Old 10-04-2017, 01:49 AM   #3
mataempat
Drives: Golf Mk6 1.4 TSI 160
Maybe of some help or not. I have a different engine that yours. It's a 1.4 TSI CAVD. I've had the same exact issue for the past year or so. Albeit only on Cylinder 1.
Carbon cleaning with walnut blasting solved the issue.
mataempat is offline   Reply With Quote
Old 10-04-2017, 02:32 AM   #4
indosilver
Coils are about $100 for a set, i would just get a fresh set of coils and a fresh set of plugs. it's the cheapest option anyways and most likely the cause of your issues
indosilver is offline   Reply With Quote
Old 10-04-2017, 02:43 AM   #5
Stock-GTI
Stock-GTI's Avatar
Drives: 2013 MK6 GTI
HsTuning sells the coilpacks and spark plugs bundled. 94.99 for a set Red tops by themselves if I remember correctly.
Old 10-04-2017, 09:07 AM   #6
jrm_gti
Drives: 2009 GTI
I did try swapping coils around and still get the same result. But I will throw in some new ones anyway.
Mataempat, I am thinking this is my problem. Car has 118k and I'm not sure if a carbon cleaning was ever done by the previous owners .
Car still has the original intake manifold too, not the updated one. Prob going to have to replace it , and see how those injectors are holding up as well.
Thanks for all the replies, I'll try to keep this updated.
Old 10-04-2017, 09:46 AM   #7
FriggenT
I'd try something simple like the gumout valve cleaner spray. Use it through the temp sensor hole, if you can tell any difference at all, that's likely your issue
Old 10-04-2017, 09:51 AM   #8
Carlosfandango
I agree with this^
Iíve used a similar product in the past
https://www.carparts4less.co.uk/cp4l...saAhJaEALw_wcB
It did a good job but a proper carbon clean is the only real answer!
Old 10-04-2017, 10:05 AM   #9
FriggenT
Originally Posted by Carlosfandango View Post
I agree with this^
Hmmm, how did that stuff work? Not familiar with that brand in the U.S. obviously
Old 10-04-2017, 10:22 AM   #10
Carlosfandango
I guessed you wouldnít recognise the brand,
It actually worked better than I thought it would!
Hereís some info from their website,
https://www.wynns.uk.com/wp-content/...eaner_EN-2.pdf
Old 10-04-2017, 11:45 AM   #11
FriggenT
I guessed you wouldn’t recognise the brand,
Here’s some info from their website,
Excellent, check this out...notice the carbon that comes out and he also has borescope pics https://youtu.be/hHF-Jdw0eto
Old 10-04-2017, 12:26 PM   #12
Carlosfandango
When I used the wynns product I got a lot of carbon out of the exhaust (far more than in the video) and it ran much much better once I was done, for unrelated issues Iíve since then had a new head and inlet manifold and PCV so I should be good for a while but I intend to use the cleaner again soon as a preventative measure, like he says in the video if itís done on a regular basis there should never be any large build ups and a full clean will not be necessary, Iíve only used the wynns stuff though so canít really make a judgment on other products.
Old 10-04-2017, 12:31 PM   #13
FriggenT
I'll have to look for it in the U.S. and give it a try
Old 10-04-2017, 02:12 PM   #14
Carlosfandango
http://www.wynnsusa.com/
