Old 10-09-2017, 10:10 PM   #1
bequietanddrive
bequietanddrive's Avatar
17x9 +30 ET - any issues?
Hi all, I am specifically looking at these wheels:
http://www.ebay.com/itm/17x9-ESR-SR1...kAAOSw3pVZ2T1Q
Or at least something with similar specs. Would I be able to safely run these with 225 tires with strut/fender clearance?
I am on coil-overs at about 24.5 FTG all around.
bequietanddrive is offline   Reply With Quote
Old 10-10-2017, 12:10 AM   #2
Blakcard
Blakcard's Avatar
They look real nice, you rolling yer fenders to clear 'em?
Old 10-12-2017, 11:02 PM   #3
bequietanddrive
Well, I'm trying to find out if that's necessary? lol!
Old 10-12-2017, 11:15 PM   #4
Blakcard
Blakcard's Avatar
Well I'm on 18x8.5" on stock suspension running 225... I did the fender mod just in see and it's only with a full tank and huge bumps down a good speed that I graze the tires.. pretty sure next up for me is when I drop in a set of springs that I will have negative camber on the rear hoping I avoid rolling the fenders
Old 10-17-2017, 11:56 AM   #5
dadbodk04
Drives: MK6 GTI
a 225 tire is going to look like crap stretched on a 9" rim and the performance is going to be terrible. If you aren't slammed it'll look dumb as well. You need to run at least a 235/40 with that, and a +30 is pushing it, I would look at a +35 which would still be extremely aggressive.
I'm running a 18x9.5 +40 with a 245/40 on a lowered car and I'm doing it without over fenders, but it took a lot of time and work to stop the rubbing.
dadbodk04 is offline   Reply With Quote
Old 11-06-2017, 10:33 PM   #6
bequietanddrive
Thanks for the info guys. I will likely try to run a less aggressive setup as the wheels above are too heavy for my taste.
