Old 10-22-2017, 04:58 PM   #1
threadbare
Drives: 2013 R
MK6 R Brake Questions
I have a 2013 R and I recently ordered a PowerStop brake kit from Auto Anything because it was on sale enough that it was (could be) worth it - the kit has drilled and slotted rotors and ceramic pads. Other than cosmetic, I'm sure the rotors won't be a huge increase since my car isn't much more than stock.
Anyway, I started the replacement process today and I noticed that the pads I was sent for the fronts have sensors embedded in both sides and the idle (non-piston side) pad has a retaining clip.
I have a VW service manual and it shows 2 or 3 types of brake systems, 2 kinds for an R. The stock pads don't have sensors and that idle side pad doesn't have a clip.
Am I correct in assuming that 2012 and 2013 then have different brake set ups and I was just sent the wrong pads? I feel like clipping the wire off, since it doesn't have anything to connect to on the car, wouldn't hurt anything, but it also looks like the pad wouldn't be able to wear all the way since there is a sensor embedded in it. I'm not so keen on removing the clip from the back, but if that is a common thing to do, so be it.
Has anyone run into this? What are your suggestions?
threadbare is offline   Reply With Quote
Old 10-24-2017, 02:26 PM   #2
Lao278
Drives: 2012 White Golf R
I would contact PowerStop directly and let them know what the problem is and tell them the part number you received. They could've sent you the wrong pads since only the piston side should have the brake sensor. Also the brake sensor should only be on the front left brake caliper I believe.
White 2012 Golf R, Milltek turbo back exhaust, VWR cold air intake, HPFP, Bilstein PSS10 coilovers, APR stage 2+ tune, R8 Coils, BSH catch can, Snow Performance stage 2 w/m injection, BSH throttle pipe, Arm FMIC, Eurosport X brace
Lao278 is offline   Reply With Quote
Old 10-24-2017, 03:43 PM   #3
B6JoeS4
B6JoeS4's Avatar
Drives: 12 CSG DSG 4D GTI
You can just pull hard on the wires coming out of the pads and the sensor will pop right out. That's how mine has been for a long time now.
It is also worth mentioning that my 2012 GTI only has the sensor on the drivers side. So if you are working on the passenger side and not seeing the sensor, that might explain what is going on.
APR Stg2 v2.4 || AWE intake || Cobb TBE || ARM FMIC || 034 Mounts || Depo LED's || Podi || Alzor Peelers || Eibach ProKit || R32 Brakes
B6JoeS4 is offline   Reply With Quote
