Old 10-29-2017, 03:09 AM   #1
Carlosfandango
Carlosfandango's Avatar
Drives: 2010 MK6 GTI 6MT CSG
2010 GTI front hub/wheelbearing replacement
Does anybody know the latest revision part number for the front hub/bearing assembly for a 2010 GTI please? And could a different failed part mimic the sound of a failed bearing such as the drive shafts for example?? Iím at 118000 miles, thanks.
Old 10-30-2017, 07:16 AM   #2
TimS
Drives: '12 Golf R
I had a bad ball joint that cupped my right front tire; it sounded exactly like a bad wheel bearing.
Old 10-30-2017, 08:34 AM   #3
Carlosfandango
Interesting! Although Iím getting a noise that sounds like classic failed wheel bearing Iím not sure it is, it doesnít really change when loading the bearings when turning (weaving) and Iím not 100% sure thereís play with the car jacked up, whatís the best way to check the ball joints?
Old 10-30-2017, 09:09 AM   #4
TimS
Drives: '12 Golf R
Mine was making noise, so it was pretty easy to diagnose. With that corner in the air, pull the tire vertically to check for play. If there's no play in the wheel, try grabbing the control arm and moving that.
Check your tire while it's up, too. Any cupping or feathering will be obvious.
Old 10-30-2017, 01:04 PM   #5
Carlosfandango
Yeah I already checked the tyres and did a rotation of the wheels and also made sure they all were placed so they are now spinning in the opposite direction too but the noise did not change, nor did it when driving on different surfaces, Iíve just taken the car to my usual shop and they took it for a drive and checked it on a lift which highlighted the right side front bearing as the culprit, Iím going to have the front suspension refreshed as well while itís in for the bearing, fingers crossed it fixes the noise! Thanks for the help.
