Old 11-01-2017, 02:05 PM   #15
Carlosfandango
Carlosfandango's Avatar
Drives: 2010 MK6 GTI 6MT CSG
questions about led tails
Originally Posted by nature boy View Post
yeah, left hand drive, canadian 2010 golf 2.5 sportline. looking at your list i'm actually thinking 04 is what i should try. there are so many diy's and a multitude of codes for various things, but i guess i can just try them all and see which one works...
thanks again
Iím in the uk and use 04 so probably wonít work for you? Iíll have a look as I did have a different list but not sure if Iíll be able to find it any more,
Worth a shot though hey!
Old 11-01-2017, 02:26 PM   #16
nature boy
Drives: 2010 golf sportline
ugh, i just went outside and tried 04, 15, and 22, and i still get the bulb out error. i checked to see what code is being thrown and it said it is the reverse light. there is an led in there but i thought coding for led tails would include the reverse light?
at least i'm more proficient with the vcds now lol
nature boy is offline   Reply With Quote
Old 11-01-2017, 02:27 PM   #17
Carlosfandango
Take the LED out and put a w16w incandescent bulb in then try again, the led is probably the issue.
Old 11-01-2017, 02:42 PM   #18
nature boy
%$#&*!#$%# that was it... luckily i had a spare incandescent sitting in this bag of bulbs in my car.
so is there a way to code the car to accept led's? i have these generic bulbs for my license plate too that i don't use because of the error, but if i can code it away then i would.
Old 11-01-2017, 02:43 PM   #19
nature boy
thanks for this, by the way. such a simple fix but i didn't even think of it.
Old 11-01-2017, 03:06 PM   #20
Carlosfandango
You canít code out the reverse or turn light error but you can use a CANBUS version, not many work error free but I found these for the back up light and they work very well without error
http://s.aliexpress.com/MFVjIfAr
As for the licence plate it depends on your BCM version and vehicle year, as youíre a 2010 it will likely not take the code even though the option is shown in VCDS (09 central electronics),
I use some in-line error decoders for my genuine licence plate ledís, Iíll try and find you a link.
Old 11-01-2017, 04:52 PM   #21
nature boy
thanks man, i appreciate it.
so... turns out it wasn't the bulb. i just got back from lunch and driving there was fine, but when i reversed out of my spot the bulb out light went off again. I wonder if the previous owner of the tails did some hackjob to clear the errors or something, i did notice some oddly placed electrical tape on one of the wires. just a thought.
i have a whole bag of w3w led bulbs that i was using for my plate but stopped because of the codes and stuff. if i'm getting an error regardless i just might throw them back in.
ugh, i didn't think a simple taillight swap would turn into all this lol.
Old 11-01-2017, 05:04 PM   #22
Carlosfandango
If itís the back up wiring youíre referring to The tape could be from where they attached an error canceller, i take it youíve actually checked the back up light works?, with the right coding you wonít have issues, the backup light will only trigger a fault if youíve used reverse gear, try the different codes again and make sure the bulb is working and that the error is not for a different bulb.
Old 11-01-2017, 05:29 PM   #23
Rickybobbi
I have the hallogen 2.5L and Im pretty sure I changed my code to 1F. It took out the bulb out error. But if you want to put LEDs for your reverse and turn signals i would check out DEAutoKEY. I have not purchased from them but a lot of people on this forum swear by them. I just used the regular lights for my turn and reverse.
2011 GOLF 2.5// LED TAILS // 18" BLACK RIMS // 2 12" KICKER SUBS // REAR EMBLEM BLACKED OUT // FRONT EMBLEM BLACKED OUT // DE-BADGE REAR // LED INTERIOR // HID HEADLIGHTS // 8" ANDROID HEAD UNIT // 35% TINT ALL AROUND // FK STREETLINES //
Old 11-01-2017, 05:35 PM   #24
Carlosfandango
Just use the regular filament bulbs while your coding then think about LEDís later if you want them once you know your coding is correct.
Old 11-01-2017, 05:37 PM   #25
Carlosfandango
The OP has a fog light by the sounds of it so I doubt 1F would work!
Old 11-01-2017, 05:49 PM   #26
nature boy
i don't know if there was an error canceller put in at all, it looks like the tape was just wrapped around the wires for some strange reason. i guess i could pull it off to see what's under there. i attached a pic of it.
the reverse light works for sure, both the led and incandescent. and after i swapped them out and changed byte 18 to 15 (as it is now), i doubled checked all the lights and everything is working as it should. but still a darned bulb out error...
Old 11-01-2017, 06:01 PM   #27
Carlosfandango
As it has tape on the yellow and brown wires I would think it has had a canceller taken off and some tape stuck on!
Try some different codes and see what happens,
This link may help,
http://www.golfmk6.com/forums/showpo...3&postcount=87
Old 11-01-2017, 06:04 PM   #28
Carlosfandango
Iíve just thought! Did your car have a rear fog from factory or did you have two back up lights? Could be a factor if the car thinks the fog is a reverse light and finds it is led!
I think this was mentioned earlier in the thread so you may need a euro switch to remove the error.
