Old 11-01-2017, 06:10 PM   #29
nature boy
Drives: 2010 golf sportline
no rear fog from the factory, and changing byte 18 is supposed to clear that up (that's why there is a rear fog option and non-fog option). i think i'll just change it back to 22 and hope for the best. if it is still on then whatever, at least the lights all work and look awesome lol.
nature boy is offline   Reply With Quote
Old 11-01-2017, 06:10 PM   #30
nature boy
thanks for all the responses and help, especially carlos!
Old 11-01-2017, 06:17 PM   #31
Carlosfandango
Carlosfandango's Avatar
Drives: 2010 MK6 GTI 6MT CSG
questions about led tails
No thatís not correct! If you have a fog from factory your coding will be for rear fog and if you donít have rear fog from factory and set it to rear fog but donít have a fog switch it wonít work, if you started with two back up lights then fit a fog but no euro switch the fog will come on with reverse gear and trigger the error as it is led and there is no code that removes the errors for the backup lights, this I would say is your problem, get a euro switch and you can then code it to except the fog and not put voltage to it when in reverse.
Old 11-01-2017, 06:18 PM   #32
Carlosfandango
22 is for RHD so that will also throw a code!
Old 11-01-2017, 06:20 PM   #33
Carlosfandango
I think 15 is your code but you need a euro switch mod.
Old 11-02-2017, 06:05 PM   #34
notovicrious
notovicrious's Avatar
Drives: 2011 GTi 2.0T
Originally Posted by Rickybobbi View Post
I have the hallogen 2.5L and Im pretty sure I changed my code to 1F. It took out the bulb out error. But if you want to put LEDs for your reverse and turn signals i would check out DEAutoKEY. I have not purchased from them but a lot of people on this forum swear by them. I just used the regular lights for my turn and reverse.
Bingo...I got a 2011 and had all halogens. Replicas had a fog, my guy changed byte 18 to 1F and was able to get rid of all issues with any ledís. I had one reverse light and the fog was on before this was done. After the tweak I had no fog and 2 reverse. He did almost all the vagcom mods including auto lights off when ignition off. I never installed a euro switch and wonít need the fog in Jersey. DeAuto sells all canbus that work with these cars and theyíre covered for life. No brainer.
Old 11-02-2017, 06:09 PM   #35
notovicrious
That tape would be the deal breaker for me bro. Also nobody in theyíre right mind would sell OEM for $120 lol. IMO theyíre reps and somebody chopped them up and avoided spending money on the right equipment and or coding.
Old 11-02-2017, 06:47 PM   #36
Carlosfandango
Did this mean the back up light and led fog came on together with reverse gear engaged? But no error?
Old 11-02-2017, 06:50 PM   #37
notovicrious
Originally I had errors for the led tails including reverse and turn signals. Fog was always on unless I went in reverse. In reverse, the passenger side was on and not the fog. After I put it in drive, reverse off and fog came on.
Old 11-02-2017, 06:55 PM   #38
Carlosfandango
After the coding what does the fog do when in reverse gear? Is the fog a non removable LED?
Old 11-02-2017, 06:57 PM   #39
notovicrious
No more fog. I have two reverse lights now. Fog was removable.
Old 11-02-2017, 07:08 PM   #40
Carlosfandango
Ah, ok, I could be wrong but I think the OP said they have a sealed LED fog which (as Iím sure you are aware) would trigger an error using 1F as the reverse bulbs cannot be coded for LEDís, so I think in their case they would need to code for having a fog (15) and do the euro switch mod, or get another inner light cluster with a removable bulb and code (1F) as you have done.
Old 11-02-2017, 07:11 PM   #41
notovicrious
Thats correct. If itís sealed then a switch is needed. Not sure on the coding. I wish I knew more about vcds.
Old 11-02-2017, 07:55 PM   #42
Rickybobbi
I'm pretty sure when I got the lights they were with the fog but I never put a euro switch and trigger wire( I could care less about the fog light in the rear), just coded to 1F and problem solved. OP should try 1F, who knows it might just work and if it doesn't then just put it back to what it was before.
2011 GOLF 2.5// LED TAILS // 18" BLACK RIMS // 2 12" KICKER SUBS // REAR EMBLEM BLACKED OUT // FRONT EMBLEM BLACKED OUT // DE-BADGE REAR // LED INTERIOR // HID HEADLIGHTS // 8" ANDROID HEAD UNIT // 35% TINT ALL AROUND // FK STREETLINES //
