Old 10-30-2017, 09:04 PM   #1
gtiGreateness
Drives: 2011 CW GTI Autobahn/DSG
235/40/18 +35 on GTI
Sorry of this has been posted already. Got a buddy with a set of vmr V710 that he's selling at a heck of a deal. Want to see if the setup will fit on my car. I am stock ride height. The tire + rim is as follows.
235/40/18 Tire
18x8.5 +35 Rim
Thanks,
gtiGreateness is offline   Reply With Quote
Old 10-31-2017, 01:18 AM   #2
Blakcard
Blakcard's Avatar
Slight rub.. 225 would fit better but still doable.. fender screw mod needed I believe... test fit and see?
Old 10-31-2017, 11:16 AM   #3
Stock height you'll probably be ok.
Old 10-31-2017, 06:23 PM   #4
Kestrel
Kestrel's Avatar
Drives: 2014 K04 GTI
That's what I have on my GTI (235/40-18 on a 18x8). I'm lowered a bit and the fender screw mod was all I needed to do. Now, if I REALLY push the car into corners downhill...it just understeers rather than rubs. You'll be fine at stock height.
Kermit: 2014 GTI, APR K04, Snow Performance Stage 2 W/M system, United Motorsport ECU/DSG tune, Neuspeed FMIC, VWR intake, 42DD downpipe, Milltek Catback. Avery Grass Green Vinyl, wrapped by Xerographics Hawaii in Honolulu and Spectrum Auto in Colorado.
Kestrel is offline   Reply With Quote
Old 11-01-2017, 08:28 AM   #5
jordy6
jordy6's Avatar
Drives: Vw golf mk6 1.6 TDI
How do you guys run these offsets, i have 8" wide et42 rim and already poke a bit on the front. I don't think that there are any differences with that with the normal golfs and the gti and r
Old 11-01-2017, 09:30 AM   #6
Kestrel
Kestrel's Avatar
I run about 1.5 degrees negative camber up front, and the wheels are flush (near as makes no difference). The rears have a ton more room.
Old 11-01-2017, 07:59 PM   #7
gtiGreateness
Thanks guys for all the information... Ended up purchasing these bad boys! Hoping I can survive the long winter without putting them on.
rims, tires, wheels
