Old 11-01-2017, 06:46 PM   #1
jordy6
jordy6's Avatar
Drives: Vw golf mk6 1.6 TDI
I want to lower my tdi
I need some advice with lowering my golf. I want to lower it with lowering spring. I would like to know how low I can go without rubbing, I'm ok with doing the fender screw mod but I don't want to start rolling my fenders. i don't want a slammed look it just needs to be cleaner. My wheels have maybe a few mm of poke but are basically flush with the fender.
I was thinking of lowering it about 20-30mm would that give any rubbing?
(Looks much higher than it actually is in this pic lol)
Old 11-01-2017, 08:51 PM   #2
Roctre
Roctre's Avatar
Drives: 2011 CW GTI
I run the VWR springs on my GTI, which is around a 20mm drop and I have no rubbing or problems during winter.
Old 11-01-2017, 09:34 PM   #3
jordy6
jordy6's Avatar
Thanks a GTI is stock lower so I can go a bit more than 20mm I guess.
I don't know how it works in other countries but the reason why I want to know it is because it has to be done by an official garage with all proper documents and it has to get through inspection afterwards which is not cheap to do so I want it all to be right the first time.
Old 11-10-2017, 05:49 PM   #4
SyDiko
Keep in mind, springs are going to be a static drop and all performance springs are manufactured to mainly eliminate 'wheel gap.' That concept might not fair too well during your inspection, that said you might want to look at adjustable coilovers if passing that inspection is a concern.
Good luck!
