Old 11-07-2017, 02:09 AM   #1
Stock-GTI
Stock-GTI's Avatar
Drives: 2013 MK6 GTI
Wga Preload/adjustment
Those of you running a forge wga how did you adjust it ?, I know the longer the rod the easier the wastegate will crack. How much preload should I put on the wga. Forge said 2-3mm at most. I'm pulling the turbo adjust it, and I want to avoid having to do it again. I'm using the yellow spring 10-14lbs, want it close to the weakest setting. Overboosting like crazy right now. Thanks for the help.
13 Mk6 GTI DSG | Stratified | Integrated Engineering | Cobb Tuning | Turbosmart | ARM | Forge | GruvenParts | Fluidampr | Neuspeed | Spulen | NGK |
Old 11-07-2017, 03:08 AM   #2
FriggenT
Why are you pulling the turbo? Is it not on yet? The preload is just that, 2-3 mm from the end of the rod.
Old 11-07-2017, 03:17 AM   #3
Stock-GTI
Stock-GTI's Avatar
I need the turbo inspected as well as adjusting the wga. It's already on there, I did what you said to test it and it's way too stiff, gotta adjust it. If I remember 2-3mm is 4-5 half turns. I'll either adjust it myself or run it by a local turbo shop.
