Old 11-09-2017, 11:39 PM   #1
shadowblue2013
Drives: 2013 shadow blue gti 2dr
Mysterious power loss 3-4k WOT APR stage 2
Recently developed a power loss at 3-4k from mid-low rpm wot. usually gears 4-6. I have sifted through several forums, but have not found anything concrete.
45k stock clutch, stock coils and spark plugs. Stage 2 APR v2.4 low tq file.
Plugs and coil packs are due for upgrading, although I have had no misfires or stored any codes/ displayed any CEL through vagcom. So I don't want to start replacing things that may not be the culprit.
Manual transmission: The clutch was my first suspect, but after noticing that the clutch is not "slipping" (revs don't shoot up briefly) and I have not smelled the clutch burning, I dont think its the clutch.
Gears 4-6 WOT: starting at ~2.5k rpm, rpm rises, climbs to about 3.5k and BAM.. hits a brick wall. power loss & rpms drop. 1-2 seconds later they pick back up and continue to climb (slower then normal).
The car feels much slower overall.
Logs show boost values are consistent, not showing me a boost leak. GFB DV+ installed.
Clutch doesn't display the classical slip symptoms, although during the power loss the indicator which tells you what gear you are in goes away, as if in neutral.
No stored codes via VAGCOM or CEL present. No misfires as well.
Anyone else have a similar experience? I have emailed APR and have yet to receive a reply.
shadowblue2013 is offline   Reply With Quote
Old 02-02-2018, 09:16 PM   #2
DarienMidnight
Drives: 2012 vw gti 4dr autobahn
Was this ever solved ?
Baltimore Maryland
APR stage 2 / r8 coils / APR stage 1&2 intake / AWE CBE/ APR catted DP so basically i have and APE TBE ( FMOIG: YoungRios_ )
DarienMidnight is offline   Reply With Quote
Old 02-02-2018, 10:25 PM   #3
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
Slipping clutch.
Old 02-02-2018, 10:25 PM   #4
GroceryGTIer
Drives: 2013 black Wolfsburg
Surge
Old 02-02-2018, 10:35 PM   #5
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
Nah that's definitely a slipping clutch.
"Clutch doesn't display the classical slip symptoms, although during the power loss the indicator which tells you what gear you are in goes away, as if in neutral."
Is a clear sign it's the clutch when it's happening. My rpms didn't spike like everybody else claimedit would either, it didn't exactly as the OP said when my clutch was slipping.
Old 02-03-2018, 07:11 AM   #6
GroceryGTIer
Lol, I waa kidding
Old 02-03-2018, 10:04 PM   #7
DarienMidnight
No time for games lmaoooo
Baltimore Maryland
