Old 11-10-2017, 07:00 PM   #1
LAGP
Drives: Audi A3
A3 8p compound turbo K04/GT45 build
In the past 5 years I have learned a lot from various forums and use that information to modify my car with the intention to have a better road car with good sport performance and occasional 1/4 mile race. Here is a graphic story of my Cars evolution from stock K03 to whatever it evolved into, English is not my language so I will not put much detail in the descriptions but if someone have a question fell free to ask and I will try to share whatever experience I gained.
LAGP is offline   Reply With Quote
Old 11-10-2017, 07:07 PM   #2
LAGP
Drives: Audi A3
Can follow trhead here:
http://forums.vwvortex.com/showthrea...#post108614633
Old 11-12-2017, 07:22 PM   #3
Chris659
Drives: 12 Beetle Turbo
Tell me more about the DSG cooler relocation!
Did you have to add an auxiliary pump or anything? What cooler did you use?
Old 11-12-2017, 08:58 PM   #4
LAGP
Drives: Audi A3
No pump needed, adapter plate goes where the OEM heat exchanger used to be. I'm using a 10 row radiator with -10 an hoses I bought on eBay. I fabricated the plate from 12mm aluminum plate cut with a reciprocating saw drilled and taped 2 NPT to AN -10 fittings exactly over the DSG ports with a template and flattened the bottom side over Emery cloth on a glass surface including the fittings that protuded a little bit. I used one 90 and one 45 to clear the exhaust crossover pipe.
Sent from my Moto G (4) using Tapatalk
Old 11-12-2017, 09:08 PM   #5
LAGP
Drives: Audi A3
Did my first pull from stand still today and feels almost exactly as it did prior to the addition of the larger turbo. I'm using torque app to measure 0 to 60, not really accurate but gives a good idea of the performance
Old 11-13-2017, 10:33 AM   #6
CHerna
CHerna's Avatar
Bienvenidos compa!
| Stratified Pro-Tuned | Eurojet TBE | Integrated Engineering Stage 2 CAI | R8 Coil-Packs | GFB DV+ | BC Racing BR Series Coil-Overs | Rotiform KPS | OEM Lagunas | Nitto NT555 G2 |
IG: @MightyCarlitos
Old 11-13-2017, 11:45 AM   #7
APRMK6GTi
APRMK6GTi's Avatar
Subbed, looks like an amazing and crazy build
Nor Cal VW Drivers Club
Old 11-17-2017, 06:45 AM   #8
U-20T
Drives: BT GTI4Motion
Your clutches are going to slip extra early with that cooler but glad to see it’s running. When are you tuning it.
Old 11-17-2017, 10:57 AM   #9
LAGP
Drives: Audi A3
why do you think the clutch will slip? I have not decided how to tune it yet, I'm working out the details on the installation first, PCV valve is giving me a hard time, it is not able to contain the oil under boost.
